Setup for roval?
  • priapism
    • 1182
    Setup for roval?
    Should suspension be setup any differently for a roval than for a standard road course?
    -Sean : 91 Calypso 325i : Castro Motorsports SoCal Spec E30 #33
  • NigelStu
    • 827
    Loaded side on the oval may need more ride height and more tire pressure, depending on speeds, how steep the banking is and how much of the oval you are running.
    Ben
    Thelma-Louise, the '88is Chump Car - back to M20 power!
    2014 ChumpCar Season Schedule!
    April 5-6 Autobahn, IL - Sat: 1st! Sun: 3rd
    May23-25 Watkins Glen, NY: 4th, 5th, 4th
    October 4 PittRace Sprints: 2nd in C-class
    October 18-19 NCM, Bowling Green KY: 2nd, 1st!
    Nov 1-2 Watkins Glen - Chumpionship - 1st car to exit the race with significant body damage :(
    Find us on FB! Schaut Speed Motorsports
    • priapism
      • 1182
      1 turn. The corner that we run flat out isn't an issue, it's easy flat, wondering more about top speed. We spend a loooong time flat out.
      I'm running thinner oil (5w40 Rotella syn) and put a new air filter in. Guess I'll just run my usual suspension setup /shrug
        The best setup for a roval is going to be a normal road course setup. A significant fraction of the lap time on a roval is in the twisty bits. So optimizing the the car for the part of the oval used penalizes the car in the twisty bits. As is usually the case, getting a little more speed through the corner that leads onto the oval is going to make the biggest difference.
        • carnurd
          • Jul 2009
          • 110
          Cal speedway is a 2 mile oval and se30 will be wot for nearly 30 seconds if not more. the infield is made up of low speed turns and long straits. No highspeed turns except turn 1. So fresh tires are an absolute must. The OP experienced that when you saw the norcal guys at buttonwillow.
          1991 BMW 318is Track Car-NEEDS ITBS AND STANDALONE!!
          1997 BMW 328i Daily Driver-like buttah..
