Question about brake setups for those of you with 24v motors...
  • seatown88
    • 331
    Apply the temperature paint on the rotor in 1 inch+ segments. Surface prep is critical to the application of the paint, you want to make sure that the rotor is clean before applying the paint.
    After they see a specific heat, they will change color. This picture shows my rear rotors reaching a temperature over 1100F.
    • dude8383
      • Jan 2005
      • 10387
      Originally posted by NigelStu
      Edge of the rotor and edge/back of the brake pad backing plate.
      Yeah, we ran without ducting first couple of races. Never had pad or fluid fade (Cobalt friction pads / ATE or the new Prospeed RS683 fluid), but we were also driving the car keeping in mind we needed to run a whole 7 hours, so not as hard on the brakes. Just more wear/heat than I like to see - you know shit is getting hot when wheel weights fall off when the car is sitting in the pits! (forgot to add tape to a wheel...)
      Yeah, knock-back can/will happen first corner, not time dependent.
      It sounds like you've narrowed it down correctly that there is too much heat in the system for how you are using the car. Small/thin pads, no cooling, higher speeds than stock and greater braking needs = too much heat. Add some cooling, maybe step up to a higher heat-tolerant pad. If still having issues, up-size the pad.
      Awesome. Thank you man, really appreciate the help here.
      As for up-sizing the pad... well I'd have to actually up-size the whole caliper and then I'd probably have to address the smaller rear. Hope that maybe just these few tweaks can make for a more solid system. I'm not really looking to race the car because I'd be way out of my league with whichever class my car falls into. This is more of a DE/track day car (at least I keep telling myself that).
      Thank you sir. Appreciate your feedback in here as well.
      Hopefully next season will be time less spent on bleeding brakes and more time spent lapping/learning!!!
      • JRKOUPE
        • Dec 2004
        • 3159
        D
        You know I wish u the best of luck in sorting this...as Ill b following your lead. I do not want to go 5 lug.....and bigger brakes really limit the use of 15 inch wheels...
        and oh...w/ pad knock back, :you often see well versed drivers tapping the brake pedal on long straights just to reseat/reposition the pads for the next corner...
        • Frankensteined
          • May 2012
          • 162
          I would judge from all the things said, and the picture in your sig, is that your fronts are doing all the job, and rears are not doing much.
          I had an e30 that the cylinder went bad and would only brake with fronts, so check that.
          Also bleed your system.
          And as stated above. Build some cooling ducts. use something like the accordion style duct for dryers.
          just my 2c
          • dude8383
            • Jan 2005
            • 10387
            Originally posted by JRKOUPE
            D
            Heh, thanks buddy. I'm looking forward to some worry free track time. The only proper option is e30 m3 5 lug which would allow you to keep the 15" wheels but the "cost of entry" if you will is super high.
            Ahhhh so that is the official term for it then. I've seen this multiple times (on youtube of course) and understood that they were reseating the pads.
            just my 2c
            The temps from lightning (where that pic was taken) were 600+ for the fronts and 200-300 in the rear. So yeh, the rears were barely working. Having said that, the rear were definitely working at Thunderbolt yesterday because the temps were around 400 or so.
            How does one really know if the m/c is just working the fronts? Is there anyway for me to visually inspect it cause I'll remove the damn thing and make sure its operational! I really really want to get to the bottom of this over the winter :D
            Going to do the 2 man method this time around when bleeding. I got lazy at the track because I had the motive speed bleeder. I am ALSO going to rebuild my rear calipers.
            Thanks guys.
            • 2002maniac
              • 4260
              Wow those are getting seriously hot! At this level of track performance I'd say good ducting is mandatory. I have tried most of them and I think that Meyle does make the best blank Corrado rotor. You might want to try the Racing Brake rotors (have not tried them, too pricey for me). I think ducting alone will probably solve your problem, but you might end up needing the greater thermal mass and pad area of a larger rotor/superlite setup. Good luck!
              • seatown88
                • 331
                I would stay away from Racing Brake, too many instances of cracking most likely due to poor metallurgy, plus poor design.
                • Frankensteined
                  • May 2012
                  • 162
                  The way I figured it out is pretty easy. Get it on a lift(if you have one), start it up then put it in gear, and brake while running. Mine would lock the fronts, but the rears were barely rubbing, not enough to stop the wheels. Usually the pedal would feel like it goes further than usual.
                  Best of luck for a solution.
                  • Grinch337
                    • May 2005
                    • 38
                    Hey Denis did your master cylinder ever go dry? I thought I may have once puked out all my brake fluid and I was concerned about whether putting the pedal to the floor blew out the master cylinder. I was given advice that I may need to bench bleed the master cylinder. It turned out I didnt need to do it, but its something you may want to do. It could also help you determine whether there is air trapped in the abs unit.
                    Here is the thread where I was given the advice:
                    http://grassrootsmotorsports.com/for...r/50898/page1/
                    Really want you to get this figured out. It wasnt as much fun out there knowing that you were in the garage struggling with this all day.
                    Sean
                    • dude8383
                      • Jan 2005
                      • 10387
                      Thanks for chiming in man.
                      I just ordered a set of hats from Lee and I'll be picking up rings from Emory motorsports. Hoping that the design will improve cool and I will DEFINITELY be purchasing ducting. I want to cover all fronts here! Wish I could go with a bigger caliper but then I'd have to address the rear. I'm also going to get a bias valve so that I can really dial things in.
                      Yeh, so I've heard... but then again I'm going with a slightly different setup now anyway.
                      Interesting. I'll give this a shot the next time I have the car up on the lift! Thanks.
                      Sean
                      Hey dude. How was the rest of the day? Manage to get a few more runs in?
                      Good thread but I'm positive that I've never let the master cylinder run dry. I remember when I swapped over to the 7 series master from my buddies car I had made sure that there was fluid in there prior to fully removing it. He had it in the car for a very short period of time and had zero track days on it so I wasn't worried about the condition of it. To note, I've had over 15 track days on my current master cylinder.
                      I feel like the pedal feel is related to the extreme temps that my calipers are seeing. I'm going to get that paint as well for next season so that I can get a better idea of what the temps are... granted I'll have the bias valve, better rotors and ducting. Figure it will make sense to know these things anyway.
                      Btw, I'll try and get your video up on the tube sometime today or tomorrow :)
                      Slight aside, I also started a thread over on bfc:
                      Lee provided some useful info too.
                      • Grinch337
                        • May 2005
                        • 38
                        Yeah, I got one or two more sessions in. I had a great time overall. I didnt think the bench bleed would help you, but figured I would throw it out there so that you're sure youve covered all bases. Good luck with figuring it out.
                        Thanks again for letting me borrow your camera. Im looking forward to the video. No rush though.
                        • dude8383
                          • Jan 2005
                          • 10387
                          Nice. I'm jelly!!!
                          • 2002maniac
                            • 4260
                            Good to know, I had not heard this.
