Weighed my car yesterday
    2536lb 54% front 46% rear
    1/4 tank gas
    4 point cage
    no carpet
    no rear seat
    s52 swap
    i need to remove some more weight off the front wat do you guys think
    Bmw 332i 260whp 240wtq N/a
    Lexus GS400 280whp
    wow! That is really light for an M50 swapped e30. Have you removed the A/C and powersteering? That should help a little bit.
      that sounds...too light?
        Mine is 2650 with full interior minus back seat, has a roll bar, m50, no A/C comp, with p.s. It is an 86 Euro MTechnic1 with the stock Euro bumpers full skirts, etc.
        1988 Alpine white M3
        1985 Delphin gray 323i, "Junkyard Dog"
          david where did you weigh your car?
            strategic
            a/c was removed when I did the swap i still have the power steering though
            thinking about a fiberglass hood from IE in the future with some other strategic weight removal every bit counts into making the car have a better power to weight ratio
            Lexus GS400 280whp
              Our club has corner weight scales. We set them up from time to time at events. In 2 weeks at our dyno day, they will be used again.
                Sick. I'm guessing that you removed all the sound deadening? Aftermarket seats? Hopefully my car will be just as light, if not lighter as I won't have a cage for a while.
                '91 318is
                  M52 Roadster block. :D
                  Trevor Ely
                  '95 M Sport 540i - '00 A4 1.8TQMS - '85 190E 2.3-16
                  '88 535is - '87 325e - '89 325is - '91 318is - '90 325is - '96 328is
                    You can weigh your car at any truck weight station.
                    87 325IS - Delphin Grey/Cardinal
                      My old 318is was fully dressed in the interior when i weighed it. Minus AC, PS, and Radio and straight pipe exhaust to save weight. With a full tank and spare in the car it was 2455 at summit point raceway
                        Not bad.
                        Trevor Ely
                          Re:
                          Do you have the eccentric front CA bushings or a way to increase caster. That helps a little by altering the wheelbase.
