So someone pretty much just gave me a 3.73, but, its a one-wheel-peel so that sucks! Thinking of welding it and thowing it in and seeing how it works! What do you think? I not really a daily driver, pretty much just weekends and cruising!
4:10 or 3:73 for mostly drag use?
Torsen is 0.4 seconds slower than clutch lsd in 60ft section.
Much cheaper to run though
The best option hands down for drag racing would be welding the diff (SPOOL). GO STRAIGHT; 100% locked.
Welded is cheapest and also the lightest.
If op is running a m50tu turbo than turning the car to street drive/park is not a problem; he can use his right foot.
Sent from my GT-N7100 using Tapatalk 2OBD1 M54/M52TU swap as a M50b25
Ha thanks wanganstyle!! I think i might try it. got two diffs for $50 so whats to lose. only takes like 2 hours to change em!Comment
Do it.
I daily drove a stock e30 with welded diff for a couple weeks, it gets some taking use to but is extremely fun and handles actually good. quite durable also; A local friend has a ground control sponsored Right drive e30 v8 truck drifting with a welded diff-OBD1 M54/M52TU swap as a M50b25
Rebuilding since 07/06/2016
Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
Poorboyz Feedback ThreadComment
Been trying to practice the ebrake thing some and it seems to work pretty good! I'm hitting the track again thurs night so hopefully it'll work out better! I'm still running the 4'10! At poorboyz, i've never done it before so who knows, it'll pry take me a little longer than 45. Maybe if i did it again i could do it a little quicker!Comment
I would suggest the 2.93 since your boosted. The lower gear will load the motor quicker and spool the turbo faster. Your tire height also affects the gear ratio. What size tire are you running?Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
____________________________
E-mail Panayiotisx2@gmail.com
Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=ULComment
Do the math for trap speed and calculate the gears needed for 1320; powerful cars dont need to shift much.
Are you staggering the launch boost? Usually like 10-15-20psi depending on gear
G260 is very long with 4th gear 1:1. A local e36m drag car at 1,000rwhp I setup with 3.64 final drive; 3.1L built engine with gtx45r turbo out the hood and mustang TKO 5 speed with 4th gear 1:1. 8krpm redline
he trapps 160mph and 9.0 sec with a 1:1 4th gear/3.64 final and 1krwhp
2.93 is to damm long with a g260 ;) esp for one with less than 500rwhp.
I'd baseline with a 3.73 welded and drop down or up depending on take off. Drag slicks and heavy duty driveshaft shop axels will be smart items for durability/efficiency
Line lock/brake boost will also do wonders for 60ft if the car is setup to HOOKUP.
Got nitto nt555r tires coming tomorrow! They are 245/50/16. And ya i'm a tad over 300whp so i can't have too long of gears. I'd like to invest in some axles but don't really have the money right now! :( Oh well sometime soon!Comment
All stock bolts. Dropping it is easy, putting it back up is a little trickier.
Tools needed:
19mm wrench
17mm wrench - also to be used as a leverage tool for the 4 19mm bolts that hold up the diff from the top side.
19mm socket with breaker bar
7mm Allen socket...3/8s preferably
Those are all the tools you need.
Sent from my Galaxy Nexus using Tapatalk 2sigpic
DREWLIENTE
