How to know if my ecu had being chipped?
  • Elliot
    • Feb 2006
    • 83
    I just bougth a 1989 325i and I saw what appears to be silicone around the ecu screws. I want to crack it open to check if the ECU have an upgraded chip. Any thoughs on how to identified new aftermarket chips?
    Thanks
    Elliot
  • Snowmann
    • Jan 2004
    • 459
    Not like R3v's track forum is worth a fuck, but why is this in here??
    and to answer your question, I believe my conforti chip had a sticker, look for a sticker
    • Brew
      • 3060
      Get your car going about 45 miles per hour, then stick it in second gear and floor it until you bounce of the rev limiter. Stock rev limit is ~6400 rpm I think, most chips raise it to 6900 rpm
      '91 318is
      • rs4pro3
        • 5808
        simple take the engine to redline if the needle goes above 6500 before the ecu kicks in the revlimiter, it's chipped.
        85 325e 2.7 ITB'd stroker
        • bimmer8604
          • 3017
          usually u can tell if the ecu has been opened, the tabs will be scuffed up or there will be scuff marks on the ecu.
          kyle
          1988 M3, 97 840, 99 XJ
          DILLIGAF
