Not being able to afford new rubber for my 15" wheels, I bought some used R3S04's in 225/45/14, hoping to mount them on a 6" bottlecap. The previous owner of the tires said he used them on 6" and it is a stretch, but will work (He raced a CRX).
-Will the bubbling sidewall be a problem?
Next concern:
A 225 tire on a bottlecap might just rub the inner fenderwell on an E30. This didn't come to mind until this morning, does anyone have experience with using 225's on b-caps? I have some 8mm spacers that I can use if necessary. Height is no problem, the car isn't totally "slammed" in the rear.
Tire Pressures?
I've only run 225/50/15 ES100's at the track, I got them way too hot and tore up the treads. I know R-comps can handle more abuse, but do I set the pressures similar to street tires? (32/34 cold)
Any other general tips for a first-time on a hoosier? If any racers can throw in some input from their transfer from street tires to R-comps at drivers schools, that would be just what I'd like to hear.
Thanks,
Stu
Next concern:
Tire Pressures?
Thanks,
Stu
