Help me fix my setup, yay!
  • Dave
    E30 RAT
    • 11675
    Originally posted by rs4pro3
    With adjustable links you can get almost the same affect also.
    I think I said that - cabrio bar with adjustable links. . . .
    Current Cars
    2014 M235i
    2009 R56 Cooper S
    1998 M3
    1997 M3
    • Dave
      E30 RAT
      • 11675
      Originally posted by PeaveyBassist
      Learn to control your car instead of changing the car to suit your driving style bitch.
      Will
      :loco: :loco: :loco: :loco:
      And watch out for those minivans. Bitch.
      Current Cars
      2014 M235i
      2009 R56 Cooper S
      1998 M3
      1997 M3
      • Bavarian3
        • 1230
        Under braking?
        • rwh11385
          lance_entities
          • 18403
          Will
          shut it. don't make me sneak a IE 22mm bar and install it in your rear, then bitch at you to adjust to the car mother fucker
          • Bavarian3
            • 1230
            Answer my question, or I will go back to studying bio-foundations...
            • rwh11385
              lance_entities
              • 18403
              Originally posted by Bavarian3
              Under braking?
              no, after that. maintence throttlin' it felt like it wanted to swap ends on me... and being it was always near the turn 9/10 which is the only place with a wall, i quickly found a fix.
              • PeaveyBassist
                • Sep 2004
                • 3511
                Heeter... I'll kill you. Dave too...
                Will
                RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                Welcome e30 (brilliantrot '90 325is) 12/23/06
                DaveCN = Old Man
                My signature picture was taken by ME! Not by anyone else!
                If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                • rs4pro3
                  • 5808
                  Ya you did.
                  85 325e 2.7 ITB'd stroker
                  • Bavarian3
                    • 1230
                    I think you shouldn't worry about your setup rather than maybe getting some better tires... I mean your setup is only as good as your tires, to be honest...
                    You can do what ever you want in theory (on paper) and then only apply it to be wrong. If that makes any sense....
                    Though you said the car doesn't have any oversteer with the rear bar disconnected?
                    • rwh11385
                      lance_entities
                      • 18403
                      It works pretty beautifully on Falkens with no rear bar. Pretty confidence inspiring, or at least not in a cold sweat the rear is going to swing around on me. It does what I want it to and is predictable on track. Even with a Spec Miata'er having me push the car harder and faster.
                      It just obviously isn't a "solution" in my book. My rear rolls hardcore before 475#'s are too soft for this shit.
                      So let's see if i can get this cabby bar, modded or not, and with adjustable links and get a balanced car. Or just take Jay's successful advice.
                      • Skafrog
                        • 1730
                        why is not running a rear swaybar not a solution? Does it not give you the desired end effect?
                        This whole discussion is stupid. Running no rear bar is a very good way to produce a great handling e30. If you still find you are oversteering, then install m3 links, or a cabrio bar, or even both. With all the slamming you do on this forum, you should know how to achieve the deisred effect.
                        Your solutions range from absolutely rediculous and expensive to cheap as hell. Why dont you just install m3 tabs and m3 links since you already have them, and then go to the track.
                        NASA MidSouth TT Director / GTS2 #018
                        Mods: Coastal PS Fluid, 10w40 Oil
                        Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
                        • Bavarian3
                          • 1230
                          lol...
                          • rwh11385
                            lance_entities
                            • 18403
                            it's effects aren't as productive in a parking lot dodging cones
                            • Dave
                              E30 RAT
                              • 11675
                              Robert, have you been tested for ADD?
                              Current Cars
                              2014 M235i
                              2009 R56 Cooper S
                              1998 M3
                              1997 M3
                              • Skafrog
                                • 1730
                                Well, if its not as productive, then do what you basically just said in a round about way. Apparently we are using deductive reasoning.
                                Go get some stiffer springs, or get some stiff as hell swaybars. Easy.
