Track wheels
    Track wheels
    Building my first track car at the moment 2.8 m20 turbo should have 300+HP, and looking into getting some rota grid 15x7 +20 wheels because they are light and cheap, and in Australia.
    My question is will 205/50/15 semi slick tyre offer enough traction.
    or should i get 15x8 +0, and run a 225/50/15
    And I plan on running The willwood 295mm front brake kit, and yet to find an equivalent rear kit.
    Please offer me some recommendations, to suit.
    329i
    wider option always.
    will 15s clear a BBK though?
    check out massive brakes for a rear kit. you may find a front kit you like better from there as well
    IG: @mitchlikesbikes
      Yes the 295mm kit is for 15",
      Thanks ill have a look.
      329i
        15x8 +0 isn't going to be fender friendly.
        Get the 7" +20 and play with spacers if need be, or look into another wheel.
        1991 325iS turbo
          Another option is a 16x8 et20.
          Is 16" to big for track?
          I'm running H&R Race springs, with billie sports.
          329i
            i will be running 16x8 +15 and 225/50 tires. my car will be a summer daily and light track use car. i like beefy fitment though, so you could run a 225/45 as well. most say the 16" tire selection is shit but you can get direzzas, RS3s, advans, hoosiers, R888s, and potenza re11s in that size. i don't know what else anyone would want really
              Ok, yeah I plan on either toyo r888 or Yokohama advan A050"s they both come in 225/45/16
              329i
                I have found some 15x8 +20 (maybe a spacer required)
                they should do the trick with some 225/50/15 semi slicks?
                329i
                  I have 15x8 Konigs that are +20. They just baaarely clear the stock strut housing with a 225. Small spacer would be better, but not critical.
                    I run 15x8 Konig Wideopens in a +20 offset. They are so close to the strut housing in the front that clip on weights hit the housing. Running those with a 225/45/15 Nitto NT-01's and 5mm spacers up front has worked well for me.
                    sigpicLevel Motorsport: www.levelmotorsport.com
                    Instagram: https://www.instagram.com/levelmotorsport/
                    Facebook: https://www.facebook.com/LeVelIndustries/?fref=ts
                      Thankyou,
                      I think thats what ill have to do aswell,
                      I just purchased some rota grids 15x8 et20.
                      329i
                        I also have a 295mm BBK in the front and there is a reeeally limited number of 15" wheels that will clear it.. Just keep that in mind before you pick something up.
                        R.H.D
                        M-technic I club
                          I don't have a BBK, but I run TR Motorsport C1s in 15x8 with Hankook Ventus RS-3's in 224/45/15s. I had to roll my rear fenders but the fronts clear and they really handle the power of the S52 pretty well.
                          2014 GTI | 2002 Land Cruiser | 1991 Volvo 745t
                            15x7s fit a 225 tire pretty nicely...
