E30 Lap times at Watkins Glen
  • Esprit
    • Nov 2009
    • 33
    Please post lap times for your car or someone you know for circulating around Watkins Glen. Provide all info as below. Try to keep the same format if possible.
    Starting off:
    EVENT: Reisentoter PCA DE, July 27-28, 2014
    LAP TIME: 2:32
    CAR: Esprit Motorsports 1991 318is
    STREETABLE? Yes
    ENGINE: M42 w/ inverted header turbo, 5.5 Psi, 24lb injectors, 1992 Saab 900 Mitsubishi/Garrett TEO5-12b turbo and intercooler, Esprit single row timing chain conversion, lightened 3251s flywheel , COP
    DRIVETRAIN: 3.45 LSD
    CHASSIS: weight reduction, sump guard, 6 pt. Safety Devices roll cage, 6 pt harnesses, old Momo start seats, lowered steering column, Momo steering wheel
    SUSPENSION: All stock except 2" H&R lowering springs
    WHEELS/TIRES: Stock 14" basketweaves, Falken Azenis 195/60-14
  • FredK
    • 14762
    EVENT: COMSCC WGI 9-11-2012
    WEATHER: 82 and sunny
    LAP TIME: 2:39.7
    CAR: 1991 318is
    STREETABLE? Yes
    ENGINE: S54 with EBay headers
    DRIVETRAIN: ZF320 and S2.93
    CHASSIS: Bone stock, 2625 lbs with full tank of gas and no spare tire
    SUSPENSION: TMS J-stock
    WHEELS/TIRES: 15x7 with 225/45 Hankook R-S3
    RICER EXCUSES: I had just finished swapping my car a few weeks prior, and took it up to WGI a couple years ago. My brake bias was a little messed up, as if I braked hard for T1, the car got extremely squirrelly, and the same thing was true at the bus stop. I've since swapped my braking system to a dual MC with balance bar. I also had a bad driveshaft. It didn't actually do anything but it made me nervous when I heard a loud grumbling lifting off the throttle.
    I've gotten a lot more track time and have a much better feel for what my car is doing with a roll bar and harnesses.
    I won't be able to make it up to WGI with COM this year, sadly. I really really wanted to see how much time I'd gain with the additional experience I have. Maybe if I can find an event later in September I'd make the trek up there.
    Did you run an AiM or other timing device? That's the only issue I have with BMWCCA is that generally speaking, they do not allow you to run one. I guess you can run a video camera and retrospectively see your lap times, but honestly, getting an AiM has been my best learning tool, besides seat time and setting my car up right.
    I bet I could chop a bunch of time off, because a 2:39 is painfully slow.
    • spoth
      • Sep 2012
      • 23
      EVENT: ChumpCar Summer Jam, May 25 2014
      LAP TIME: 2:28.316
      CAR: Rage Cage Racing 1987 325e
      STREETABLE? Not really, no, but that doesn't stop me.
      ENGINE: Chipped M20B27 (eta)
      DRIVETRAIN: 2.93 LSD
      CHASSIS: Full road race car. 6pt weld in cage, seats, all of the low hanging fruit for weight reduction
      SUSPENSION: Cut stock springs, Sachs shocks, fixed front camber plates, everything else stock
      WHEELS/TIRES: 15x7 Kosei K1, 205/50 Falken Azenis RT615K
      Fastest E30 single lap time at the race was a 2:24.327 (M20B25).
      • squidrope
        • Dec 2012
        • 291
        LAP TIME: 2:28.316
        That's very impressive being that close to an "I"'s time.
        • spoth
          • Sep 2012
          • 23
          Thank you. The fastest M42 time was a 2:25.xxx, from a team full of BMWCCA guys from Syracuse, so my guess is the B25 cars were a little inexperienced.
          Last year's E30 FTD was a 2:19.xxx, IIRC. The rules are much more restrictive for BMWs this year, though, which has slowed things down for us. (That car had front Wilwoods, 225 Rivals, camber plates, and almost assuredly a mostly Spec E30 suspension)
          • Jb325is
            • 2137
            One of our Spec Miata's did a 2:15.9 this summer. You guys are lucky to be anywhere close to this place, what an awesome track!
            - '88 m54 coupe
            <3
            • emagdnim33
              • 24
              Best track in the good ole US of A
              • squidrope
                • Dec 2012
                • 291
                Lose the Armco and I'd agree...
                • L8 Apex
                  • Apr 2007
                  • 169
                  EVENT: Northeast Quattro Club HDPE 2013
                  LAP TIME: 2:25
                  CAR: 1990 325i
                  STREETABLE? Yes
                  ENGINE: M20, Miller Performance 3" PSIK, MAF conversion, and WAR chip. Electric fan conversion, Stahl header with 2.5" custom exhaust. A/C and CC delete. Custom oil filter and oil cooler setup.
                  DRIVETRAIN: 3.73 LSD, OEM flywheel machined to 12.5lb
                  CHASSIS: front and rear subframe reinforcement, front and rear strut braces, 4 pt. VSR roll cage, 5 pt harnesses, Corbeau TRS seats, Momo steering wheel
                  SUSPENSION: GC coilovers, camber plates, Koni DA front and SA rear, Eibach sways front and rear, Treehouse Racing CABs
                  WHEELS/TIRES: 16"x7" SSR Comps ET35, 10mm spacers, Toyo R888 205/55-16
                  Too many mods, so little space...
                  • NigelStu
                    • 827
                    Almost - I pulled a 2:23.885 on Saturday And I thought one of the EC cars ran faster than that.
                    LAP TIME: 2:23.885
                    CAR: Schaut Speed Motorsports / Bavarian Mustache Werks 1988 325is
                    STREETABLE? Not so much. Suppose it could be
                    ENGINE: rebuilt stock M20B25, Bimmerhead stock rebuilt head
                    CHASSIS: Full road race car. 6pt weld in cage, seat. Approx 2400 lbs with me in the car (big heavy cage, nothing else in the car). Front splitter.
                    SUSPENSION: Cut stock springs, Sachs shocks, re-drilled front shock towers (UPR spring top-hat touching inside of strut towers), poly bushings all around (except for sway) no rear sway bar.
                    WHEELS/TIRES: 15x8 TRM, 225/45 BFG Rivals
                    Ben
                    Thelma-Louise, the '88is Chump Car - back to M20 power!
                    2014 ChumpCar Season Schedule!
                    April 5-6 Autobahn, IL - Sat: 1st! Sun: 3rd
                    May23-25 Watkins Glen, NY: 4th, 5th, 4th
                    October 4 PittRace Sprints: 2nd in C-class
                    October 18-19 NCM, Bowling Green KY: 2nd, 1st!
                    Nov 1-2 Watkins Glen - Chumpionship - 1st car to exit the race with significant body damage :(
                    Find us on FB! Schaut Speed Motorsports
