H&R race springs on the street ??
  • s52e368
    • 539
    anyone ??
    opinions ?
  • Mastrcruse
    • Sep 2005
    • 5340
    Do you want to keep or lose your teeth? Not form experience but I was told that they will raddle your teeth out fast. It might be okay if its not a DD
    • s52e368
      • 539
      hmm..
      its going to be a dd ..
      • Dave
        E30 RAT
        • 11675
        I'll chime in. I had them with Bilsteins on my Convertible - they were streetable IMHO. Springs and how they affect your ride is very subjective.
        i would not hesitate to DD a car with H&R Race Springs. Hell, right now I am frequently driving with 475/650 linear rate GCs - and I dont find it too objectionable.
        You might also see if RCWells can advise you. He DDs on Race Springs.
        Current Cars
        2014 M235i
        2009 R56 Cooper S
        1998 M3
        1997 M3
        • s52e368
          • 539
          thanks DAVE
          • rwh11385
            lance_entities
            • 18403
            It's all about what size sidewall you have. Tires are a vital part of suspension, and if you are running 16s or 17s, you'd be murdered. I know on my soft GCs, 16s jarred me.
            Factory-size tires and 15s aren't too harsh, and 14s... comfortable. If you are in a city with bad roads, they might get to you.
            I'd personally go for Sports for a daily driver, since if you mod your car FUH RAZE then it's good 5 days a year, but sucks 360.
            • Dave
              E30 RAT
              • 11675
              To follow up on what he said ^^^^^^
              On my 'vert, I ran it both with 16s and 14s. The 14s were a better ride. I wouldnt say that it was jarring with the 16s, but it was rougher.
              Current Cars
              2014 M235i
              2009 R56 Cooper S
              1998 M3
              1997 M3
              • Rob
                • 8166
                I'd say the low height is a bigger hassle than the spring rates. H&R Race are progressive arent they?
                BEERTECH
                • Dave
                  E30 RAT
                  • 11675
                  Indeed (x2)
                  Current Cars
                  2014 M235i
                  2009 R56 Cooper S
                  1998 M3
                  1997 M3
                  • e30sd
                    Fistee
                    • Jan 2004
                    • 5517
                    eh i'm not saying this like i'm some cowboy rebel but it's not that bad. besides, it really depends on what shock vavling you are running.
                    • s52e368
                      • 539
                      progressive ??
                      reason i ask, i plan on maybe going spec in the near future.
                      so they'll be on 15"s
                      • Rob
                        • 8166
                        progressive springs start out with a lower spring rate, and as the spring is compressed, the rate 'progresses', ie gets stiffer. So basically they have a low spring rate for small bumps and imperfections, but a higher rate for turns and other larger body motions.
                        If you're going SpecE30, might as well start learning the spec suspension now...
                        BEERTECH
                        • Dave
                          E30 RAT
                          • 11675
                          Well, if you plan on running "spec" I assume you mean SpecE30. So then you will be on H&R Race and regular off the shelf Bilsteins.
                          IMHO that will be tolerable on the street.
                          Current Cars
                          2014 M235i
                          2009 R56 Cooper S
                          1998 M3
                          1997 M3
                          • rwh11385
                            lance_entities
                            • 18403
                            the springs get stiffer as they compress, instead of the same stiffness with linear spring... like on a coilover perch.
                            if you are looking to spec, just put them on. rock out with 205-55-15 tires for now on the street.
                            • JRKOUPE
                              • Dec 2004
                              • 3159
                              Some good responses here by drivers who know.......
                              I run HR race on 15's w/ GC Koni SA's...I set my car up similiar to Spec but not exact. Its tolerable but for a DD i would not do it. I drive as much as 5 hrs to tracks w/ a race seat........ok but not fun. Its hard to say....but if you are paying for labor and may run Spec..then do it, if not then do IE springs......similiar rates and cheaper. PM me...I may go J stock....Ill sell you mine.....whats your time schedule......?
