Hood Louvers/Vents
  • george graves
    • 19996
    Originally posted by nando
    :p
    But, but, but.....the OP is in Australia. So he needs it on the underside - a undercarriage vent. Heat rises ya know.
    Originally posted by Matt-B
    • Ether-D
      • Sep 2011
      • 2838
      Then all this driver side/passenger side talk may be slightly misleading.
      Originally posted by Andy.B
      I was born on 3/25…
      • Navarone
        • Jun 2014
        • 935
        What side of a chicken doesn't have feathers?
        The inside! Lolololol rabble rabble!!
        • jalopi
          • 2370
          if you actually spent some time with the bodywork and paint it could actually come out pretty decent. i used a steel hvac register/vent and a set of sheet metal clamp things (http://www.harborfreight.com/8-piece...mps-60545.html) plus some body filler.
          you'd be surprised at how much air it actually flows
          • jules325i
            • Jul 2011
            • 353
            Well it will be on my drivers side. right above my turbo
            329i
            • rcsoundn1
              • Nov 2012
              • 3361
              it may flow air, but looks exactly like an ac vent. Maybe Im to picky but there has to be better ways to get air flow.
              • Navarone
                • Jun 2014
                • 935
                Hood Louvers/Vents
                Speed holes, duh!
                • IronFreak
                  • Dec 2012
                  • 3702
                  I work for a fabrication shop and picked up some of this machine perforated aluminum i'm going to use for vents. nice and light, thin enough to mold into a position but stiff enough to hold form.
                  Instagram @rebellionforge
                  • kts
                    • Jun 2010
                    • 753
                    Some ideas for you from what irish44j has done with his rallycross car:
                    • jules325i
                      • Jul 2011
                      • 353
                      They actually came up alright i'm impressed.
                      However my first attempt i'm going to be using Ford T-Bird reverse scoops symmetrically either side, colour coded to blend in. As well as delete both high beams and put in 4" intake funnels in there place.
                      Could look horrible but I'll have to wait and see stay posted.
                      If it looks crap ill get a new bonnet and get some of that aluminium meshing and go down that route.
                      329i
                      • Eric
                        • 5142
                        • AlpineCoupe
                          • Jan 2013
                          • 70
                          Not as clean/ classy as the last post but effective...
                          Also, racecar
                          • Eric
                            • 5142
                            Did it help?
                            • camshaftgsxr
                              • Aug 2011
                              • 416
                              one of these http://www.cool-wheels.com/shop/wp-c...05/as2-16K.jpg off to the side above the turbo, buddy of mine has a 700ish hp urs4 5zylinder and you can literally see the heat rushing out from above the turbo when moving. plus its a design from the 80s
                              BroWorks.com Bro is a lifestyle
                              • Hooffenstein HD
                                • Nov 2012
                                • 1388
                                One of these should do the trick?
