rallycross?
  • Jordan325iC
    • Aug 2005
    • 1697
    rallycross?
    This just popped on my local autox club site:
    *** October 15th - SCCA Spokes RallyCross - Austin ***
    Where: http://tinyurl.com/mn32p (cut-and-paste URL)
    When: October 15th, regular autocross schedule (below)
    What: The first ever SCCA/Spokes RallyCross in Austin! Spokes is teaming up with the Lone Star Region SCCA to bring new motorsports to Central Texas! RallyCrosses are very similar to autocross but instead of running on asphalt or concrete, we will be running on grass and dirt! That's right, time to bring out all of those Subarus to see what they're made of! More RallyCross info as well as car classifications can be found on the SCCA website (www.scca.com). Spokes will be adding a few classes of our own to up the fun factor including a "claimer" class that will limit expenses and make it possible to build your own RallyCross car before the event!
    I was wondering if anybody had tried this in an e30 before? It sounds fun as hell, but my car is lowered ~1.8" so I'm not sure if my car can handle it. Anybody attended one and know how extreme these courses are? Can normal road-cars make it around without loosing too many pieces?
    '88 325is
    VP UT of Austin Autoholics
    BMWCCA 380364
  • ddavidv
    • 344
    I wouldn't run an alloy sump car on one that has been lowered until you SEE the course. Courses vary widely in 'quality', and they also tend to get a lot worse as the day goes on. You can get some real deep ruts sometimes and will bottom pretty easily.
    • Rigmaster
      • 3464
      Rallycross is a blast. Your E30 should be OK, but you might want to fab up a skidplate for the oil pan if the ground is hard or has lots of rocks or roots.
      In general, RWD is not as good as FWD in a rallycross, but it's still fun as hell, and RWD throws bigger roostertails than FWD.
      Just go try it once, you'll be hooked.
      Bret.
      • rsafier
        • 164
        Yeah I did it in my lowered rusty 325is before. Probably about same level of drop, had Eibach Pro springs on it so whatever that drops. One of the few things I found more fun then Autocross. Was also kinda fun to see a E30 with an aggressive driver can beat out all the Subies that show up. In the mud they go to one-wheel drive due to having all open diffs (at least most that showed up at the event I went to). I used a set of WS-50 snow tires and provided a lot of grip.
        Really other then a lot of dust no major damage. Did have to fix the bumper a little (it was hitting on compression off of some ruts). And tore a tie-rod boot. Well worth it for the fun factor. Still searching around for a cheap car for a dedicated RallyX car.
        SM 19 - Serial Destroyer of Cars
        Turbo '89 325i - It lives! Now the question is for how long?
        2SlowRcing.com
        • Jordan325iC
          • Aug 2005
          • 1697
          It turns out non-caged cabbies can't run in rallycross, so I'm out of luck. Too bad, because it sounds like a ton of fun.
          '88 325is
          BMWCCA 380364
          • getfast
            • Sep 2004
            • 124
            About to try my hand at rallycrossing an E30 this weekend:
            http://www.get-fast.net/e30rxb/
            Can't wait,
            Jon
            two ///Moneypits and a toaSTer
            "Power and speed solve many things." -Jeremy Clarkson
