15x9 & 15x8 6UL for E30
Need 15x10 damnit.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
Originally posted by iitsMikE30 View PostJongbloed JRW series 500 15x10 at phils tire service
They don't look bad, not expensive, and 57.1 but ET10 would need to check how they would clear front/rear (on the inner side agains coilover in the front) and rear shock.
Have you ordered one to test fit ?Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
Originally posted by LJ851 View Post
May still order these.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
Originally posted by Jean View PostI just did :) Thank you! So they are Miata spec wheels (again , damn!) Why doesn't someone make a set that is e30 specific since there is obviously demand.... I guess not as much demand as there is for Miatas.
Edit - You will need to modify your fenders obviously. There was one guy that was able to roll and pull his fenders enough to cover these however.
Yep, fender work is a given . What size tires are you installing on these?Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
Next question: if I purchase the 15x9 6ULs is it better to stay with a 225/45 or run a 245/40? I know it's been said on the Miata forms that a slight stretch results in faster lap times, just wasn't sure if this would also apply to e30s. For reference my e30 is a dedicated track car weighing in around 2500lbs making 300whp running GCs with aero front and rear.Last edited by TheDirtyS54Thirty; 09-22-2017, 10:12 AM.E30 S54
Originally posted by TheDirtyS54Thirty View PostNext question: if I purchase the 15x9 6ULs is it better to stay with a 225/45 or run a 245/40? I know it's been said on the Miata forms that a slight stretch results in faster lap times, just wasn't sure if this would also apply to e30s. For reference my e30 is a dedicated track car weighing in around 2500lbs making 300whp running GCs with aero front and rear.E30 S54
