Engine swapped e30s
  • kylebes1
    • May 2004
    • 2804
    Engine swapped e30s
    What are the rules, if any, about having some thing like an s50 in a early 318 body?
    Just wondering what catergory or levels that might put me in...
  • Skafrog
    • 1732
    It fucks you over in SCCA, GTS Challenge, NASA Time Trials. However, if you are going all out, you will be able to hang with the cars they put it against if you really try to make a fast car.
    NASA MidSouth TT Director / GTS2 #018
    Mods: Coastal PS Fluid, 10w40 Oil
    Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
    • joshh
      • Aug 2004
      • 6195
      In the SCCA it does fuck you up...it puts you in SM and you would need an S50 to be able to compete with the likes of competition in SM.
      "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
      ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
      • kylebes1
        • May 2004
        • 2804
        Where would an m10 or m20 Eta put me?
        • joshh
          • Aug 2004
          • 6195
          http://www.scca.com/Solo/Index.asp?IdS=08D499-A70C120&x=050|070&~=
          Download the rules. Look under car classing.
          • kylebes1
            • May 2004
            • 2804
            Thanks
            • WlknGenius
              • Aug 2005
              • 196
              Can you put in an m50 or m52 without changing class? Isn't there a clause about how youc an modernize your car by putting the newer engine in it?
              • joshh
                • Aug 2004
                • 6195
                No. There is a rule called update/backdate where IF two cars are on the same line in the rule book you can basicly use any part from either car. But if you want to take a newer motor and put it into an older car you'll be seeing Street Mod. As long as the motor and chassis are from the same manufacturer.
