Any 5 lug E30 M3 guy's run roll center spacers?
  • surebimmer
    • Jan 2004
    • 978
    Just wanted to see if any of you 5 lug guys with E30 M3 strut's are using Roll center spacers from Gustve or VAC. Like the ones here: http://gsperformance.com/products/rc-spacer/spacer.htm
    Does anyone know what is the smallest wheel size you can run with these installed is?
    thanks
  • e30sd
    Fistee
    • Jan 2004
    • 5517
    you're gonna need 17's probably.
    • Mike B.
      • Jan 2006
      • 987
      Yes, I run the spacers and have 17's. I can check clearance tonight, but I don't think you can get away with 16's.
      • surebimmer
        • Jan 2004
        • 978
        Ya that's what i'm hearing. I have a set of track wheels and tires that are 15 inch. Looks like i won't install the spacers untill all the thread is gone on the 15's.
        • Kilawin
          • Dec 2005
          • 994
          so these things kinda act like a dropped spindle?
          • Farbin Kaiber
            Lil' Puppet
            • 29502
            No. Reverse concept, more like a dropped ctrl arm/steering linkage mounting point.
            See the pic?
            • Eric
              • 5142
              I'm going to try to fit mine under 16's. but i have thinner ones from mosley motorsport. They are probably 1/2 the thickness of the GSP ones. I need to find bolts to fit them though
              • iflytii
                • Jun 2004
                • 482
                I am running 3/4" spacers from VAC and they barely fit under my 17" wheels.
