Losing Oil at the track
  • Hallen
    • 1008
    Well, the car hit the track for the first time yesterday.
    Wow, what a fun car to drive.
    Unfortunately, I was unable to run the last session, which is a shame. I didn't get any good video of the dry session so I was hoping to get some on the 4th session. But, the car was losing oil at a prestigious rate.
    I noticed after the second session that the oil was down to the bottom mark. I had topped it off before I left home. I used the remained of that quart of oil to get it back up near the top mark. After the third session, I was back down to the bottom mark again. That is almost 2 quarts used up in one 20 minute session.
    I didn't seem to be burning oil. If I were burning that much, I would be leaving a huge smoke cloud behind me. The car is definitely running rich though. It will belch out black smoke when I get on the gas.
    I didn't burn any oil that I could detect on the way home. The oil level didn't really drop any. So this leads me to guess that the g loads on the track are part of the equation. There was some oil puddling under the car, but it wasn't huge, about 2 inches in diameter after an hour on the asphalt. I am thinking maybe the oil pan gasket is bad and when I am cornering hard, the oil spews out there? Any ideas from anybody on this?
    The rich fuel mixture is probably due to old injectors. I might try some seafoam to see if that helps. I have the stock ECU in the car. The PO had a ProFormance eBay chip in it before which I removed. The spark plugs looked OK before the track day when I put in new stock ones. I have not checked the plugs yet and probably won't get to it until this weekend.
    I am more worried about the oil loss though for obvious reasons. I don't want to be oiling the track up and I don't want to be starving the engine for oil.
    1987 E30 325is
    1999 E46 323i
    RIP 1994 E32 740iL
    oo=[][]=oo
  • joshh
    • Aug 2004
    • 6195
    I'd still say you're burning it.
    Were people spinning out all th time behind you?:crazy:
    "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
    ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
    • Hallen
      • 1008
      lol, no, but I got a funny wiggle a couple of times in turn 4 that made me wonder if I was oiling my own rear tires.
      The track was in pretty nasty condition anyway so most people were taking it pretty easy.
      If I were burning 2 quarts in 20 minutes, you would definitely see it in the exhaust, it would be very dense. Also, I didn't burn any on the hour and a half drive back home.
      1987 E30 325is
      1999 E46 323i
      RIP 1994 E32 740iL
      oo=[][]=oo
      • joshh
        • Aug 2004
        • 6195
        That's bizarre. Compression test time.
        • PiercedE30
          • Apr 2005
          • 4220
          Check the oil level sensor to make sure it's not leaking out of there when cornering. Also dip stick seal and oil pan gaskets.
          My 2.9L Build!
          • dark89e30
            • 263
            Throw some dye in it and check it after a couple of hot laps. If that doesn't find it either check your coolant for a milkshake or do a cylinder leak down test and look for rings. You would definitely see it out the exhaust if is was being burnt, but you should also see a gaping hole if you are spilling it.
            • Hallen
              • 1008
              Thanks guys. I will check those things. The oil level sensor might be a good bet.
              I wondered why I got loose a couple of times going through turn 4, a long right hander. I bet I was slipping on my own oil. That kind of points to the sensor as a potential target.
              1987 E30 325is
              1999 E46 323i
              RIP 1994 E32 740iL
              oo=[][]=oo
