FREE WORLDWIDE SHIPPING!!
Brand New Antenna waterproof plug(USD11.49)
Installation:
Remove the antenna module and push the plug into the antenna hole.
Fits all the E30 model(82-92)
(*)Disclaimer: This is not an official BMW part and is not marketed as one.
Brand New T10(w3w) LED for instrument cluster(USD17.49)
DESCRIPTION
It is a common thing that illumination of instrument cluster on aged cars is bad.
BUT! There is always a solution!
These T10 leds are working perfectly on my E30 318i.
A package including 2 LEDS
Advantages
1. FREE WORLDWIDE SHIPPING
2. It fits BMW E30 perfectly
3. Easy installation.
4. Light color is almost the same as genuine part.
5. It shows the cluster clearly at Minimum illumination.
6. It will not dazzling your eyes at Maximum illumination.
Note:
Please make sure the bulb can be fitted in your light house before purchasing, Thank you.
1. This light is not fit for any cars directly, sometimes error code or hyper flashing occurred in some cars, add proper resistors or flasher relay, the problem would be solved. (I do not sell resistors or flasher relay.)
2. Direct replacement, require right connect to the positive(+) and negative(-) side.
If the LED does not light up, switch the LED 180 degrees, the problem would be solved.
3. If it still does not work, just contact me for further advice. I am always here for you.
(*)Most orders will ship same or next business day.
(*)A set (1 plug & 2 LEDs) just USD24.99 + free worldwide shipping.
Payment via PAYPAL
PM OR valepiy@gmail.com
Installation:
DESCRIPTION
Advantages
Note:
Payment via PAYPAL
