Need referrals for a good mechanic
  • DivineStyler
    • Jan 2010
    • 328
    I would like to have the items below installed on my e30 89 325is:
    Skip plate
    JOM adjustable suspension kit
    Control arms and m3 off-set bushings
    Front Rotors resurfaced
    Rear strut brace
    I am not looking for RAPE me prices, but I am not looking to pay for a Mr. Mickey Mouse worker... Looking for a FAIR DEAL...
    Tired of taking my car to the shop, being RAPED and them saying, THANK YOU come again...
    PM or Post... I've seen post for Castro's and Tng before, but open to anyone capable of doing a good job... I can even assist in the process...
    Feel free to PM me with a quote or estimate cost for the job...
    Thanks...
    AutoX w/ a Roof Rack for extra Aerodynamics...
  • ak-
    • 12422
    Go to Castro's. End of thread.
    Serious.
    1991 325iS turbo
    • einstein57
      • Jun 2007
      • 10780
      Castros all the way. But I think they charge you double if you help. Don't forget to have them add the m3 drop links for your sway bar.
      www.gecoils.com
      • robrez
        • Jul 2008
        • 3376
        Can't go wrong with Castro's or TNG, but e30 Motor Werks is another contender and might be closer to you.
        January 2012 COTM
        • ///digitalme
          • Dec 2009
          • 2088
          E30 motor werks a good shop, But they are pricey though. I've gotten different quotes for the same job from them.
          I say go to castro's.
            • 37833
            I do side work in the La Crescenta area. :)
            Grover Beach, California
            BimmerHeads.com
            • robrez
              • Jul 2008
              • 3376
              Word, except for the rotor resurfacing, a good backyard mechanic would be your cheapest option for the kind of work you want done. Who are the better local shade tree mechanics on r3v?
              January 2012 COTM
              • DivineStyler
                • Jan 2010
                • 328
                Word up!, local backyard boogie mechanic who can do the job is who I be lookin' fo'! I'm sure Castro and Tng can do a great job and I might have to go that route, but I prefer someone who works on there own car or cars and have done the jobs I am in need of to do it on my car for a fair price...
                • yobless
                  • 360
                  Serious.
                  Agreed...
                  Hell, if you need a skid plate I have one for sale (cheap)...waiting at Castro's for you :)
                  • einstein57
                    • Jun 2007
                    • 10780
                    I don't think he's in to men. :rofl:
                    On a more serious note I think the installation price will depend on what skid plate your installing. For example the peerless one requires welding.
                    www.gecoils.com
                    • e46s54dr
                      • May 2008
                      • 1059
                      You can definitely do some of the work yourself:
                      Rear strut brace:
                      1) Remove or bend the trunk carpet covers that cover the insides of your quarter panel by removing the tail light bulb cover and misc. clips.
                      2) Remove 4 nuts from rear strut. 13mm nuts. 2 per strut, 4 total.
                      3) Install rear strut bar. Try jacking up the car from either side or the rear diff to flex the body in order to get the bar to fit if that's your case.
                      4) Reinstall everything.
                      5) Have a beer for your hard work and enjoy!
                      Resurfacing rotors:
                      1) If doing by hand, loosen up the lug nuts but do not remove them while the car is sitting on the ground. 17mm socket or stock tire iron.
                      2) Jack up the front and/or rear of the car and remove the wheels.
                      3) Remove 2 bolts that hold the caliper to the carrier/spindle.
                      4) Detach the abs line and brake line. I believe they are held in by either a
                      single bolt or rubber grommet. Or even both.
                      5) Slide caliper of rotor and hang up the caliper with a bungee cord or rope so it isn't just dangling by the brake line.
                      6) Remove the single Allen screw that holds your rotor to the hub. Make sure you use the proper size Allen key and some wd40 because it will strip out easily if not.
                      7) Remove the rotor from the hub. You might need to give it some blows from a hammer to loosen it up if it siezed.
                      8) Go to star auto parts or any brake shop and have your rotor checked for thickness and then turned.
                      9) Reinstall everything in reverse order. This is also a good time to goop on some anti squeak lube. I like the red kind that comes in a bottle.
                      10) Bam! No more brake shimmy and uneasy feeling.
                      • e46s54dr
                        • May 2008
                        • 1059
                        As for the skid plate, coilovers, and cab/control arms, you can pay to have them done, or do it yourself. It really isn't all that complicated. Plus, if you do it yourself, it is way more gratifying and you will gain expirience. All cars are basically made the same in regards to compenents and sometimes location. Sure you can pay someone to do it, but not only do you save money doing it yourself, the knowledge you aquired is yours to keep for life. -David.
                        • accident
                          • 7303
                          castros is cheap, and they do good work. e30 motor werks can suck it purely because peerless is a douche. TNG closed their doors recently.
                          If you want super cheap though, I can do all of that except turn your rotors, but the local NAPA will do that for cheap.
                          Moral of this story?
                            • 37833
                            OP, I sent you a PM.
                            BimmerHeads.com
                            • E30Nova
                              • 1546
                              Bring that shit to my house and we can do all that shit except turn the rotors. But I used to work at the Firestone down the street so we could just take them there and get them turned for free.
                              Matt
                              I pack my CD player with asbestos. Those mother fuckers pay dearly for stealing my shit.
                              Originally posted by kronus
                              try whacking parts of the motor with a wrench while yelling "YOU WANT SUMMA DIS? HUH?"
                              This is like a reverse build thread; it starts out nice and gets shitty.
