Norcal: Need help with m42
  • series88
    • Nov 2011
    • 1231
    So I finally finished my engine swap. It's a same engine swap. My old engine was just kind of toast. So now that the new motor is in, it fires up but after about 5-10mins of idling, it starts getting rough and bugs down. When I turn the engine off and start it again, it will run fine for the same amount of time.
    Any ideas?
    I wanted to take the car down to bfest but it seems like it wont be happening :(
  • freeride53
    • 11972
    Check for vaccum leak(s) and make sure your spark plugs are installed properly.
    1983 Peugeot 505 STI
    1992 Volvo 240 Wagon
    • series88
      • Nov 2011
      • 1231
      ^spark plugs are ok. That's the first thing I checked. Still searching for vacuum leaks
      • series88
        • Nov 2011
        • 1231
        Anyone in the bay area willing to check it out? Car is in the Fremont area
        • bmwm42
          • 6300
          make sure all your sensors are connected temp sensor oxy sensor. by the sounds of it your car is staying in closed loop mode.
          Originally posted by bmwm42
          PNW vulture pm me for parts
          Strategic nw e30 command
          • series88
            • Nov 2011
            • 1231
            Will be checking that tom. Thanks for the advice:)
            • series88
              • Nov 2011
              • 1231
              btw: i got to solve the problem a while back. It was some plug in the harness that was not plugged in when we started the swap but decided to plug it in after. I unplugged it then it ran fine.
              Got lots of oil leaks now though. Got to go through the whole thing again
