advice on bent uni body.
  • J.Rizo
    • Aug 2012
    • 949
    so, long story short, i bent my frame. well, "frame".
    i was just wondering if you guys have any advice on what i should do with the car.
    i bought it for 1,600 but in total i've spent about two g's on it.
    my options are get it rolling and sell it, and buy another e30.
    part it out, and buy another e30.
    or keep it.
    i know its bent, buuuut i dont think its bent too severely, will i run into problem down the road if i keep it?
    thanks guys!
    @joshua.j.rizo
    Originally posted by SpasticDwarf
    Just remember next time you hear "late night when you need my love" I'm gonna be sitting somewhere way more bitchin' than you, driving or not.
    BUY MY BUGATTI WHEELS:
    http://www.r3vlimited.com/board/showthread.php?t=377693
    WRITEUP TO MY RHD SWAP:
    http://www.r3vlimited.com/board/showthread.php?t=371904
  • Cabriolet
    • 9620
    on my mtech2 vert the front was bent years ago. i found out after lowering it and that it was off by several degrees. even camber plats couldnt fix. it cost me 1700 to have it pulled and a week w/ out car. front right rail was 1" in and both towers were 3/4" back. @ that point i had 16k into my car so it was worth it. but with what you have into yours, part it.
    Much wow
    I hate 4 doors
      • 37832
      What happened to make you think it's bent?
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • J.Rizo
        • Aug 2012
        • 949
        i got into an accident and everything got shoved in. (you should see my control arm, instead of a boomerang the ends are parallel almost).
        but when i was installing my new subframe, it wasn't lining up with the rail, even with severe pulling and maneuvering. i just honed it out a little on both sides to get enough play and it fit. but now its not allowing me to not line up the motor mounts. me and my step dad tried for two days and its just not lining up.
        cabriolet did you ever run into problems with it bent though? aside from the camber plates. did it drive funny or anything like that?
        @joshua.j.rizo
          • 37832
          You need to have it pulled and straightened.
          Grover Beach, CA
          www.BimmerHeads.com
          • Cabriolet
            • 9620
            during AutoX it would over steer one way and under steer the other.
            on the freeway it would pull
            through out the chassis, early models are dime a dozen. it's gonna cost you 1000s to get it fixed.
            Much wow
            I hate 4 doors
            • Vivek
              attention whore/retard/bitch
              • 6167
              Yep find a clean shell and swap over anything that's worth anything to you, CL/PNP/Scrap what's left.
              1992 Mauritiusblau Vert
              2011 Alpinweiss 335is coupe
              2002 540i/6 Black/Black
              2003 GSX-R 750 (RIP)
              • einstein57
                • Jun 2007
                • 10780
                shell time
                www.gecoils.com
                • ///digitalme
                  • Dec 2009
                  • 2088
                  pictures???
                  depends on the damage..i had mine straighted and pulled it took about a week to have it finished....and only cost me 300 to get it pulled and aligned and 200 to weld a new core support,
                  before
                  after
                  • einstein57
                    • Jun 2007
                    • 10780
                    I purchased a running 89 325is for $750. After partout you could cash out nicely.
                    Super Eta?
                    www.gecoils.com
