Question about downpipes and smog
  • Streichholzschächtelchen
    • Jan 2009
    • 1670
    Smog time is coming for me, and my question goes as follows. If I'm running stock manifolds and a new CA legal cat but my downpipes are cracked can I have new downpipes made in stainless, stock diameter and stock routing? Or do I have to buy some form of bolt in replacement?
    Jah bless! :pimp:
  • 3vilE30
    • Jan 2013
    • 344
    I think you should be good as long as you have your o2 sensor at the stock location, if it passes out the tail pipe most smog techs don't care about little stuff like that.
      • Jan 2009
      • 1670
      What if I have the magnaflow cat for e30 in CA with o2 sensor bung on it, can I just use that bung? It has the right eo number and everything.
      Jah bless! :pimp:
      • Tinkerer007
        • Mar 2013
        • 252
        A SMOG referee told me the O2 sensor needs to be within 6 inches of the original location...
        • Bimmerman325i
          • 6854
          I would take the car to your smog shop of choice, point out the issue, and ask what are your options.
          They are the arbiters of whether it's allowed, we on the internet are not. I've had enough headaches that I wouldn't want to chance them seeing welded pipe between manifold and cats and freaking out.
          2017 Chevrolet SS, 6MT
          95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
          98 M3/4/5 (stock)
            • 37833
            There is no law about replacing 30 year old exhaust pipes. If you have the stock manifolds, proper o2 sensor location, and CA legal cat you'll be 100% fine.
            Grover Beach, California
            BimmerHeads.com
            • YosemiteSam
              • Apr 2011
              • 1303
              O2 sensor mid-cat is very different from O2 sensor in the down-pipe.
              Mid cat is used OBDII to tell if the cat is working, while the O2 in the down-pipe is used to steer the mixture.
              If you just hooked it up to the stock ecu and it was mid-cat, the car would probably fail smog both on visual and on numbers because the mixture would be all sorts of wrong.
                • Jan 2009
                • 1670
                Sensor is before the catalyst.
                Jah bless! :pimp:
