SCAL/OC - need a shop recommendation for rear subfram bushing replacement
  • mentholguy
    • Jan 2018
    • 59
    Hello guys,
    I need a shop recommendation in OC area for rear subframe and differential bushing replacement for reasonable price.
    Thank you! :up:
  • IRON-E
    • 16548
    Vaya con Dios = Good luck.
    @IRON-E30 aka Edwin:D
    • peetiewonder
      • May 2015
      • 51
      Diff bushing is easy. Just cut the rubber out then saw the metal sleeve in one area to relieve pressure. That said garagistic would probably be able to to do both for you.
      -Current-
      90 325i Coupe - Alpinaweiß II
      -Previous-
      92 525i 5speed Touring - Diamantschwarz Metallic
      03 540i Msport 6 Speed - Sterling Grau Metallic
        • 37834
        If you don't mind the drive to Santa Clarita, BimmerHeads has you covered. ;)
        Grover Beach, California
        BimmerHeads.com
        • E30SPDFRK
          • 5716
          Bullet Performance in Costa Mesa, I’m the classic car tech there and would be doing it for you.
          Byron
          Leichtbau
