Anyone have a Tranny Drain plug socket.
    I Have tried to remove my Tranny drain plug, but it just wont come off. I was able to get the fill plug out but am having no luck with the drain plug.
    I used a Nut tack welded onto a bolt, its working good, but that drain plug is just in there..... I think im on my 8th bolt as the others have sheered off where the nut ends. this time im using a heavey grade bolt and im just scared im starting to strip it, and i dont want to deal with that headache. Anyone in the area want to lend me the proper tool, or come over and give it a shot is more than welcome.
    I can buy you innout or someother lunch if you want.
    And im in Petaluma, In between Santa Rosa and Marin.
      Are you still having issues? If so, could you take a picture so we can get a better grasp on what you're dealing with.
      -Matt
      1986 BMW 325
        If you can't find a 17mm socket then get a big allen key and slide a wrench on it for more leverage. Make sure you clean the hole in the drain bolt and get your bit/allen key properly seated. Sears has hard to find stuff like this.
        If you are totally stuck get some sort of hand pump and suck the old fluid out through the fill hole ;)
        Originally posted by chileelky
        amaze about the enthusiasm e30 generate
