I need to borrow an M50 flywheel.
  • dirty30
    • 3014
    I need to borrow an M50 flywheel. I would only need it for a few days. Condition does not matter as I just need it for engine timing purposes. Stupid lightweight flywheel doesn't have a crank lock hole.
  • shEck3lls0
    • Jan 2011
    • 1154
    Why not just put something down inside the cylinder and put it to TDC that way?
    1989 Alpine 325is 2dr m50 swapped
    Build Thread:
    Current ongoing build. Check it out!
    1991 318is 4dr rallycross
    Rallycross Build Thread.
    1991 Alpine 318is coupe - sold
    • dirty30
      • 3014
      My OCD won't allow that.
      • slammin.e28
        שמע ישראל
        • 12054
        You have the tool to lock the cams?
        When I did my M3's vanos, I just got it to TDC and locked the cams. My FW didn't have the hole either (PO swapped it from auto > manual.)
        • dirty30
          • 3014
          Yeah I've got the cam blocks but I have never felt comfortable timing these without the crank pin. I'll do it with the TDC mark if I can't find one.
          • slammin.e28
            שמע ישראל
            • 12054
            True. I'm guessing the engine is on a stand?
            • dirty30
              • 3014
              Yeah and the lightweight flywheel doesn't have a hole in it. I threw a dual mass away a few weeks ago like a douche.
              • rpm620
                • 204
                hey man .. you will be fine... if the motor is on the stand you are fine.. you can see the timing marks fine.. lock the cams and good to go. This is how i did my motor.. hell even the new built one was timed that way.
                E30 Turbo 2.8L - 60ft - 1.70 :: 1/8th - 6.99 :: MPH - 105.47 :: 1/4 - 10.66 :: MPH - 132.53
                *RIP* E36 M3 - 60ft - 1.944 :: 1/8th - 8.64 :: MPH - 80.00 :: 1/4 - 13.55 :: MPH - 99.95
                • dirty30
                  • 3014
                  Found one thanks to Levent and Shane Snyder. Great guys to deal with!
