I have a nearly complete stock suspension and brake setup in excellent condition removed from a 1991 BMW 318is with 109k miles. Includes all the following:
I'm not interested in separating at this point and would like to to sell this to someone as a complete kit. Only parts needed are lcabs and front sway bar.
$450 picked up in Northern Virginia
Additional Parts Available:
Front subframe $75
Driveshaft $70
Power steering rack (no leaks, nice boots) $100
$600 picked up for everything! and I'll probably give you more free stuff
This is a really good deal! This is what you would probably pay a shop just to replace your rear subframe/diff bushings alone!
- Front strut assemblies complete with struts, springs, hubs, top mounts
- Front brake rotors, pads, calipers, caliper mounting brackets (rotors have surface rust from getting rained on once)
- Front lower control arms
- Rear subframe complete with trailing arms, 4.10 open diff (no leaks), axles with nice boots, hubs, ebrake parts including uncut cables
- Rear subframe support brackets and hardware
- Rear brake rotors, pads, calipers, caliper mounting brackets (rotors have surface rust from getting rained on once)
- Rear springs and shocks (including extra brand new shock)
- Rear sway bar
- New oem subframe and diff bushings already installed!
Front subframe $75
Driveshaft $70
