Colorado general chat...
This is a sticky topic.
  • Roland H
    • 4480
    #9106
    Originally posted by Bimmerman325i
    Yup. However, all are less egregious errors than using 'of' instead of 'have.'
    fact
    • lambo
      Captain Scene Points
      • 10953
      #9107
      • Bimmerman325i
        • 6854
        #9108
        2017 Chevrolet SS, 6MT
        95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
        98 M3/4/5 (stock)
        • iamsam
          • Jun 2008
          • 176
          #9109
          holy balls people!
          I am glad to have sparked such lively conversation with my grammar blunder.
          • Bimmerman325i
            • 6854
            #9110
            hahahaha. It's all in jest.
            98 M3/4/5 (stock)
            • iamsam
              • Jun 2008
              • 176
              #9111
              oh of course!
              my tone of voice was lighthearted and amiable when I said that
              • blefevre
                • Dec 2008
                • 4287
                #9112
                This is copy/paste from my topic I made in the tech section.
                I need to replace the rubber fuel lines on both sides of the filter. Normally when I change the filter I clamp off each hose, change filter, etc.
                Do I have to drain the tank for this or if I pop the hoses off do I only lose the gas that is renaming in the lines, or will it start draining the tank too? If it's just the gas in the lines, then I can deal with that.
                Hopefully I can avoid draining the tank, but if I have to I will.
                - E30, DSM, Golf R, Mazda 3 Skyactiv
                • iamsam
                  • Jun 2008
                  • 176
                  #9113
                  you don't need to drain the tank, the lines enter the top of the tank, not the bottom, so you will only drain whatever fuel is already in the line past the tank.
                  • blefevre
                    • Dec 2008
                    • 4287
                    #9114
                    Awesome. There is also a rubber section for the return line that I will change at the same time, but if that goes to the top of the tank as well then it shouldn't be a problem either.
                    • iamsam
                      • Jun 2008
                      • 176
                      #9115
                      They all go to the top of the tank. remove your rear seat (just the bottom part), unscrew the black metal plate, and you can see for yourself.
                      • fsmtnbiker
                        • Feb 2011
                        • 617
                        #9116
                        ... Unless it starts to siphon gas out of the tank. It probably can't pull it through the pump though, so you won't lose too much fuel.
                        Chris
                        97 M3
                        01 325
                        Weston Auto Gallery
                        • iamsam
                          • Jun 2008
                          • 176
                          #9117
                          yeah just shove the fuel line upwards to reduce the siphon effect once its disconnected. Either way, just get under there and do it! ;)
                          • Cloudbase
                            • 1795
                            #9118
                            Paging Sam. Check your email and drop me a line.
                            JOY IS AN E30...
                            • conway
                              • 366
                              #9119
                              Any one have a pelican coupon, or s50 valve cover gasket before I order one?
                              Eastwood fender roller available for rent in Boulder. PM ME
                              • iamsam
                                • Jun 2008
                                • 176
                                #9120
                                I have one for an M52, I assume it's the same
