Looking for a clutch fan tool
  • clarkkey594
    • 1724
    Anyone have one that I could borrow?
    89 325i (Sold)
    95 M3 (Track Car in Progress)
    2001 4runner (DD)
  • stoliver54
    • Apr 2004
    • 312
    PM sent
    Wheelgap is like a vagina. The more fingers you get in, the worse it is.
    Originally posted by Chachi
    young chicks are not keepers. they are for fun.
    • Atreus
      • 1846
      oh you're in boulder, i'm in denver...LMK if you still need one.
      1991 325iC - Mauritsblau sumthin metallic blue. DEAD
      1992 525i - Silber sumthin sumthin metallic- Rolling again, needs suspension/wheels/brakes/paint.... Fuck you A4S310R; BEAT YOU.
      1989 325i - Cirrusblau Metallic sumthin sumthin-project - trying to clean up the interior(done), then the body, then a 5spd, then suspension, then..... - [Stolen :| ]
      1991 325iC - Calypsorot Metallic
      1994 540i - Granitsilber
      Originally posted by scabzzzz
      I've had blunts cock in my mouth, but I'm not gay.
      • iamsam
        • Jun 2008
        • 176
        if you have no luck, I'll get my crowbar thing.
        • ZombiE30
          • Dec 2009
          • 438
          i got one too, buttfaces! now I'm in the cool crowd!
          e'erbody, come drool over my tools!
          wait.....uh.......
          Originally posted by stoliver54
          Aw, balls.
          FS: assault gear....
          http://www.r3vlimited.com/board/showthread.php?t=159253
          • stoliver54
            • Apr 2004
            • 312
            Clark is looking for this:
            Counter Holder/Fan Removal Tool
            BMW M10, M20, M30, M50, with 32mm Clutch Nut, Each (BMW Service Tool Reference #11-5-030)
            These counter holders are a necessity for removing the water pump from your BMW they are used to secure the fan hub While you remove the fan clutch pulley nut.
            NOTE: The bolts on the water pump are non-symmetric, which means that you need to rotate the fan to find the two that will fit the tool properly. Only one position out of four potential positions will work.
            http://www.pelicanparts.com/catalog/...older/3008.jpg
            • whiltebeitel
              • Apr 2007
              • 2098
              FWIW, a 1 and 1/4 wrench, filed to fit with a large flathead screwdriver has never failed me.
              '89 325i track sloot
              '01 530i daily
              -Enginerd
              • clarkkey594
                • 1724
                Yup that is what I need. Do dealers stock these tools? Or should I just order it from Pelican?
                89 325i (Sold)
                2001 4runner (DD)
                • iamsam
                  • Jun 2008
                  • 176
                  order from Pelican, and then lend it out to all the colorado peeps...
                  • monkeytaco
                    • Jan 2010
                    • 882
                    I always wrap an old belt around the fan clutch and stick a screwdriver in and twist until it holds tight, then zip off the nut with the impact wrench. Takes 3 seconds...
                    Looking for a clean e30 shell for a project.
                    • Atreus
                      • 1846
                      whiltel and Monkey are doing it right.....
                      • clarkkey594
                        • 1724
                        How the hell do you get an impact gun on the fan clutch bolt? There is the fan clutch attached to it? Do tell how this is possible.
                        89 325i (Sold)
                        2001 4runner (DD)
                        • ZombiE30
                          • Dec 2009
                          • 438
                          oh, the fan holding tool?
                          I just jam a long flathead screwdriver in between two of the asymmetrical nuts that stoliver was talking about, in such a way as to be able to apply torque in the opposite direction of the wrenching action.
                          once the bolt is even slightly loose, you don't need the holding thing.
                          Aw, balls.
                          • clarkkey594
                            • 1724
                            Yea i have tried this method but the bearing are shot in my water pump so the pulley just wiggles around and you can't keep it stable. teh lame otherwise I would have finished the job on Saturday.
                            89 325i (Sold)
                            2001 4runner (DD)
                            • monkeytaco
                              • Jan 2010
                              • 882
                              I unbolted the fan and wrapped the belt around the actual clutch, the screwdriver is used to tighten the belt, not on the fan clutch. I'm not sure what you mean by how do I get the impact gun on it? I have thinwall sockets, but I think a regular socket fit.
                              Don't forget that its reverse threads too, first time I tried to take it off I managed to tighten it so far we used a breaker bar + 3 foot metal pipe + two broken belts + lots of blood to get it loose once we figured out it was reverse.
                              Zombie said it right too, once its even a touch loose it comes out easy.
