Need an extra set of hands pulling motor - Boulder
  • conway
    • 366
    Have the whole front end off, disconnected I think every line and wire. Just need to remove the motor mounts and pull it. I need an extra set of hands to pull it out of the car, as i'm a pretty small guy. I have an engine hoist, but i've never pulled a motor before, and could use some insight as well. I use the little hook at the front of the motor?I will provide either beer, money, or car parts. Looking for help asap. Want it out of the car before the end of the week.
    -Greg
    Eastwood fender roller available for rent in Boulder. PM ME
  • BMWchubbs
    • Dec 2009
    • 183
    Car parts as in your CF door panels?
    Shoot me a text when you are Free.
    -Critter
    E36 M3 Turbo | E46 M3 6MT
    • Kvasi
      • Apr 2011
      • 1122
      Hook it up in front of motor isnt good enough. Use a rope around intake and exhaust instead, then u will get it out "in balance"
      Jack it up till the lift starts pulling, loosen all the bolts on motor mounts/transmission and jack a bit more. Then pull the motor forwards to find out what you forgot to loosen, take care of it and pull the motor further. May need to use some muscles but its kinda easy.
      • conway
        • 366
        Critter send me your number again.
        • Roland H
          • 4480
          Rope on the intake manifold? Are you f*cking stupid?
          Hook the hoist to the hook on the front, and then to the hook on the rear, then hoist up and forward. Comes right out. Double check to make sure you have the ground strap, powersteering, brake booster heater hoses, exhaust, intake, cooling stuff, fuel lines, and charcoal canister all disconnected.
          • sleepingbeauty
            • Jul 2010
            • 399
            thank god i didn't have to go there first. talk about damaging a motor. I'm local in boulder, and can give you a hand whenever your free, shouldn't take much time either if your that far along.
            508 654 1313
            parker
            • clarkkey594
              • 1724
              This is an easy way to destroy the head.
              89 325i (Sold)
              95 M3 (Track Car in Progress)
              2001 4runner (DD)
              • conway
                • 366
                Can't find rear engine hoist point, what am I missing.
                • sleepingbeauty
                  • Jul 2010
                  • 399
                  almost looks like a tranny bolt hole. should be right below where the head meets the block
                  • iamsam
                    • Jun 2008
                    • 176
                    You do not need a rear hoist point. Pull from just the front, the engine/trans dangles at a surprisingly manageable angle.
