M44 DASC + extras $2,500
  • blefevre
    • Dec 2008
    • 4287
    I have a used M44 DASC Superchager kit for sale. I bought the kit used from bimmerforums a few years back. I think it had about 20k miles on it. I started making sure I had all the parts and started gathering any additional things I should replace while in there. I never got to install it. We are working on getting new cars so this won't be getting installed.
    -M44 (96-99) that was on a 318ti. You will have to find out if it fits a sedan or an E30.
    -What I believe is the full kit minus one 45-degree bend on the intake and the MAF brackets that support the intake. You can run without them or use something to brace it if you want. It's not needed according to downing.
    -Extra fuel rail and injectors that can be sent to get cleaned a head of time
    -boost gauge with pod/hoses
    -new manifold gaskets
    -new prelude air filter. Use this instead of the K&N so you can run a proper paper filter
    -coolant hoses that attach to the block that always break anyways
    -new accessory pullys
    -new gatorback belt
    -a few new pieces from DASC
    -all new hoses
    -check valve that adds about .5psi
    -new hardware
    -extra TB, I believe a M3 one
    -air filter heat shield
    I also have the install manual and parts list from DASC on .pdf.
    $2,500
    Autometer gauge pod for a Ti/Autometer boost gauge lines/Manifold gasket/Gatorback belt/New EGR relocation block
    New EGR block piece
    Supercharger/Manifold/Elbow/Misc stuff already attached. Save install time!
    Manifold
    Elbow/Bypass valve
    Supercharger
    New hardware from fastenal and new pulley kits
    New pulleys
    New hoses. You will have to cut to length most of the hoses. I added up the BOM and bought what I needed. Comes with the used hoses as well. Lots of hoses!
    Heat shield
    Pulley brackets/New coolant pipes/boost gauge/ERG/RRFPR/Charger bracket/TB/TB cable/Fuel rail/Injectors/Check valve
    - E30, DSM, Golf R, Mazda 3 Skyactiv
  • blefevre
    • Dec 2008
    • 4287
    Added pictures for all to see!
    • blefevre
      • Dec 2008
      • 4287
      Because I know all of us own M44's and are super interested in buying this....
      Pending sale!
      • blefevre
        • Dec 2008
        • 4287
        Sold!
        • Bimmerman325i
          • 6854
          Niiiiiiiiiiice!
          Hello scoobydoo abarth.
          2017 Chevrolet SS, 6MT
          95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
          98 M3/4/5 (stock)
          • Roland H
            • 4480
            win.
            • iamsam
              • Jun 2008
              • 176
              wow that was quick.
              • blefevre
                • Dec 2008
                • 4287
                Yep, boost is easy to sell apparently.
                • monkeytaco
                  • Jan 2010
                  • 882
                  Epic win.
                  I want to see it installed on the buyer's car!
                  Looking for a clean e30 shell for a project.
                  • M-technik-3
                    • 18946
                    I was going to say put this on 318Ti.org and at that price it won't be around long.
