Flex-Hone cylinder hone FS/T
    Brush Research Flex-Hone.
    Used once, very flexible, and worked great. Much easier to use than the 3-stone. It is 89mm which is the correct size for the 84mm bore of the M20 and likely anything else in that vicinity. You want the hone to be larger than the bore.
    $25 or trade of some sort... Might be interested in a non-worn-out M20 cam, headlight brackets or an iX power steering line.
    The Flex-Hone tool provides flexible honing for your finishing and deburring needs. Learn more about our selection of flex hones by contacting a distributor.
