How much will it cost in labor to get a rocker arm replaced at a shop for my 89' 325i?
Rocker Arm Replacement
Depends on the shop. Make some calls. -
you could try...
Mike O'Hara Service Inc: Exclusively BMW
5020 NE Cully Blvd, Portland, OR 97218-3010
(503) 287-0739
I haven't taken much to him, but I think his prices should be reasonable. He should be still in business.sigpice30 Sold long ago - Too many BMWs since then... For now 2006 M5Comment
I had zero experience working on cars when I bought my e30, now I'm comfortable working on pretty much any part of the car. If you have some tools and are at all mechanically inclined you'll pick it up fast.
Buy a Bentley, do your research on R3v, and get to work (carefully). You'll save a shitload of money doing your own work. Not worth $1200 to fix one rocker arm.Comment
You could do a LOT to the head of an m20 for $1200. One of those things is most definitely not replace ONE rocker arm.
What you can do is unbolt the engine, undo the tranny from the drive shaft, get an engine hoist, pick it up a bit out of the car, angle it and pull the rocker shaft out to put a new rocker arm on. If that's too in depth for you, you can buy a complete used head for around $150-$200 and throw it on.sigpic<< wreckedComment
