Have you looked at the (trigger wire??) It goes from #6 plug wire, snakes along the front of block and connects by the diagnostic port.
Keith
Never heard of the 'trigger wire' before. Not too sure what it looks like. Is that the cps? The CPS snakes along the front of the block and connects by the diagnostic port.
It is a small wire from #6 by the dist cap. It follows the same path as the CPS wire and connects right next to it by the port. Its about a mm from the front pulley and it easy for it to get frayed if the covers not in place.
K
And this info is for an m20b25, correct? I've had a few PM's of people trying to help (thanks :)) but giving me info on an m20b27 eta motor.
Got your PM. I don't think I'll be able to make it up there any time this weekend/week. I'm swamped with work 8-5, homework (taking 3 classes) and working on cars down here. I haven't even been able to touch my customers 325 yet, and the motor is already ready to get OBD1 swapped and dropped in.
The wire they are talking about goes around the #6 wire, but up by the distributor, as was stated above. I'm not entirely sure if your motor has it.
Is a 89 and 90 325i the same M20B25? I hope so. The following info is from the 89 325i ETM. (ETM PNW's the Bentley hard, IMO, but gives no text troubleshooting advise, you have to know what to do with it http://wedophones.com/Manuals/BMW/19...g%20Manual.pdf)
Questions:
- Do you have voltage at terminal 15 on the coil (2.5mm green wire), w/ the key on engine off?
- Do you have voltage at pin 18 on the DME, w/ the key on engine off?
- Do you have voltage at pin 27 on the DME, w/ the key on engine off?
- Do you have voltage at pin 37 on the DME, w/ the key on engine off?
- When cycling the key from off to run, do you have ground at pin #3 on the DME for something like 2 seconds? (Fuel pump relay ground)
- Do pins 2,14,19,24 all have very low resistance to ground (Under, say, 0.3ohm)
- Does your check engine light come on with the key in run, engine off?
If all the above check out... You most likely have a triggering issue. As I see if, providing the DME IS indeed turning on correctly, its a triggering issue or spark issue.
ONE thing to check/answer first. Do you have an onboard computer?? Apparently, there is an Onboard Computer Relay (see that ETM above, pg "1360-4" [aka page 36 in the PDF]). I can't say I have any idea where this relay is, but to see if it is the problem, providing you do NOT have power at t15 on the coil (green wire), I would check for voltage on the input from the ignition switch to the relay (1.5mm green wire) and if there is +12v there, and NOT at the 1.5mm green/red wire, I would jumper the relay, and see if the coil then has power, and if the car starts.
Questions:
Questions:
-Yes.
-Yes.
-Yes.
- Do you have voltage at pin 37 on the DME, w/ the key on engine off? -Yes. You have to use a jumper wire from pin 2 and 36 (as says so in the Bentley).
-Didn't have anyone to help crank it. But when I jump the main relay, the fuel pump turns on and injectors start firing.
-Will go double check. Not sure how to figure out the ohm function. But all those numbers are the grounds on the ecu harness.
-Don't have one.
I do have an OBC, but I'm getting voltage at the coil with the key on, engine off.
