need$$$? i need help!!!
  • Matt-B
    The Waffler
    • 3856
    cool let me know how it goes. car wont fire first time. need to pressurize system. Dont get bummed right away :)
    • that1kidtony
      • Sep 2009
      • 130
      i still got nothing after i plugged it in. i checked the wires back on the pump and there was no power still. so... im running out of ideas
      • Matt-B
        The Waffler
        • 3856
        hmm, other bad relay? crank/cam sensor bad?
        did you spray starting flui inside maf while throttle is open and crank?
        • that1kidtony
          • Sep 2009
          • 130
          the other relays look ok i havent switched back the censors i switched earlier but i still an not getting power to the fuel pump.
          • Matt-B
            The Waffler
            • 3856
            switch them back.possible fuel pump bad etc. Or your not testing it correctly. Id buy a multimeter for like 5$ at harbor freight and an e36 bentley book.
            • that1kidtony
              • Sep 2009
              • 130
              ok i just tried the starting fluid and changed the censors back and still nothin
              • that1kidtony
                • Sep 2009
                • 130
                hmmm well i put them back i checked for power to the fuel pump on both sets of the wires and i didnt get anything. i am pretty sure the fuel pump is good i never had a problem when the m20 was in. i gonna look some more tonight and call it a day now i have very limited access to a computer, so ill be hittin the books
                • Matt-B
                  The Waffler
                  • 3856
                  try jumping the relays to force power to pump to get it to turn on...
                  • that1kidtony
                    • Sep 2009
                    • 130
                    How would I do that?
                    • that1kidtony
                      • Sep 2009
                      • 130
                      There is 3relays one is fuel pump one is o2 the other is motronic right? The fuel pump relay is new the o2 relay doesn't Really matter to start it, so if my other relay went bad the motronic one, that would not allow it to start right?
                      • Matt-B
                        The Waffler
                        • 3856
                        yes. and can prevent fuel. Its hard to explain how to jump wires.
                        • that1kidtony
                          • Sep 2009
                          • 130
                          Ok I will call kuni and get a new one so I know that both relays are good and cAn cross those out. And if that doesn't work... Idk it's gonna go in the fs add ha
                          • Matt-B
                            The Waffler
                            • 3856
                            lol nah your close. it can be as simple as a loose wire. something not tight. etc
                            • that1kidtony
                              • Sep 2009
                              • 130
                              so what relay goes where i read yesterday inn that link the fuel pump relay goes in the spot with the green and purple wire.? but currently i have a blue relay there and a green one on the left next to the big red wires and white, wich i believe is motronic or mian i guess on the right side. im going to pick up a new white one or motrinic relay now.
                              • Matt-B
                                The Waffler
                                • 3856
                                ok cool. buy a voltmeter an a book to if you want
