Das car is Kaputt... NO MOAR!!! :D
  • e30austin
    • 15382
    #46
    Originally posted by EN318isPDX
    We can hit the dip in my car and see what happens! I probably want to come along and check out your poor eta on saturday!
    What time are you off work? Abe and I are going to look at that ETA tonight sometime, maybe you wanna come with?
    '70 911s | '72 2002 | '88 M5 | '89 330is | '89 M3 | '95 911 | '02 M5 | '04 RR HSE
    • EN318isPDX
      • Oct 2007
      • 4373
      #47
      I am off work at 5pm
      • cbake82
        • 479
        #48
        I would join you guys but I'm going hashing :) lol good luck abe
        CBAKE
        86 Eta (sold)
        88 325ix (sold)
        87 325i
        • cbake82
          • 479
          #49
          Oh btw I have a new BMW master mechanic thats 40 bucks an hour and he says I can either drop the car off or wrench with him. Not sure if that will be cheaper but we'll find out tomorrow when I go over to fix my eta.
          CBAKE
          86 Eta (sold)
          88 325ix (sold)
          87 325i
          • Matt-B
            The Waffler
            • 3856
            #50
            we can swap wishnos motor in a day
            • AbeSonic
              Price check on Vagiclean, aisle five. I repeat: price check on Vagiclean, aisle five. That's Vagiclean. We've got a customer down here with a full-on fallopian fungus. I'm baking a loaf of bread and I think it's sourdough.
              • 3635
              #51
              Well the official plan is this... Compression and leak down test on Saturday. If my car fails, I'm buying Wishno's old Eta motor and doing a eta swap Sunday. lol I will literally try and do it in 1 day. I miss my car sooo much... :'(
              out dated sig is out dated
              • EN318isPDX
                • Oct 2007
                • 4373
                #52
                I will be available on sunday so let me know if i should bring anything
                • AbeSonic
                  • 3635
                  #53
                  bring party favors for the celebration after we witness the birth of my new(ish) eta...lol
                  • Eta power
                    • 342
                    #54
                    Abe, I'd like to help, so here goes...
                    You say you did a head gasket... did you mean pan gasket or did you really do a head gasket?
                    After I did the headgasket on my car it ran VERY rough, it would stall, it had no power, and it eventually vapor locked. I had the Coolant Temp Sensor the the Thermo-time switch hooked up backwards. Switched those up and it ran beautifully.
                    The way these engine management systems work, if any of the inputs (Coolant temp sensor, crank position sensor, air flow meter, throttle position sensor) are inaccurate/missing, the outputs (injectors, spark) will be effed up. There are a couple of exceptions to this rule, though: the oxygen sensor and the barometric sensor. The car will run fine without these, although without an oxygen sensor you'll damage you cat (meow). Also, if something beyond the ECU's control is not right (vacuum leak, sticky ICV, broken rocker, bent valve, etc.), it won't run right properly. Please note that some of this only applies to "normal" Eta's.
                    Here are a couple more ideas:
                    -Electrical grounds. Check to see that all are in place and working. It also wouldn't be bad idea to clean them.
                    -Because of the way these cars vent their crankcases, if there is an oil leak, that leak will also be a vacuum leak. A leaking/missing oil filler cap or an improperly seated dipstick will cause a vac leaks.
                    HTH,
                    AJ
                    Originally posted by 5Toes
                    bux bux bux. Im all about the bux Mr. Autism
                    • rickycricketts
                      • 806
                      #55
                      ^ thanks we'll check some of this out this weekend.
                      • AbeSonic
                        • 3635
                        #56
                        Rick's brother in law already check most all of those things. ICV, most all vacuum lines that are accessible, the dip stick, spark plugs and a few other odds and ends. While I did swap out my air box for a MAF adapter and cone filter I still kept all the things to it in working order. As it was my oil pan that broke....I did a oil pan gasket. >.>
                        The head gasket theory derives from the fact that we let my car at long idea for too long with a possibly faulty coolant system that could of done something some heat damage.
                        • Eta power
                          • 342
                          #57
                          A blown headgasket should have a few distinct red flags. Coolant look like a milkshake? Billowing sweet-smelling white smoke? Oil in the coolant? Consuming coolant? Cooling system over pressurizing/pressurizing quickly?
                          Also, keep in in mind that you may have REALLY bad luck (i.e. broken rocker, camshaft has split in two, timing belt slipped a few teeth, etc.). Try unplugging and plugging in the sensors one by one, see if that helps. Maybe try tapping on some of the sensors?
                          • brutus87
                            • 6280
                            #58
                            What he said...
                            • Eta power
                              • 342
                              #59
                              Any updates?
                              • e30austin
                                • 15382
                                #60
                                Originally posted by Eta power
                                Any updates?
                                +1.
                                I spoke to him this afternoon, around 1. They were preparing to do a compression test at that time.
