alright so changing brakes isnt nothing new to me, however this problem is. my front discs are vented and have girling calipers, im in the process of replacing the pads and rotors using pagid brake pads brembo rotors the fucking problem im having is the they wont go on. The brake pads are hella thick and that combined with the thickness of the rotor exceeds the space available for the caliper wtf is going on. Any suggestions anyone btw im using all stock replacement stuff.
having trouble changing front brakes
You are remembering to compress the brake caliper pistons right? If you have not then they are adjusted for the worn down pads and will not allow enough room for the new pads to fit over the brake disc.
Pictures?sigpic
Yea grab a big C clamp and compress that pistonComment
they are compressed as far back as the go. i also have spare calipers that i have tried them on and the pads combined with the rotors are to thick to fit. i just replaced my rears with no problemsOriginally posted by bmwm42PNW vulture pm me for partsComment
then you have the wrong brake pads or rotors. where did you get the pads?sigpic
This...
Then I agree with this.Comment
verify the part numbers on the boxes from your order, and the part number from part to box. I had a similar situ YEARS ago, and I got some random vw rotors in an e30 box (brembo too). GLsigpicComment
Need a part? PM me.
Get your Bass on. Luke's r3v Boxes are here: http://www.r3vlimited.com/board/showthread.php?t=198123Comment
i always think the pads are to big, but manage to get them in, what pad are you putting in first?
and are pads different for ate and girling?
mine are girlingComment
mine are girling pads are the same for all e30s im putting them both on the carrier then trying to put the caliper on. ive tried putting them on the caliper and then putting them on the rotor shit isnt happening.Originally posted by bmwm42PNW vulture pm me for partsComment
piston all the way compressed, take your brake fluid cap off to, so it can rise etc, not usre if it matters...when i compressed my piston, i thought i was done, but it went down more, and i slid 1 pad in 1 side, and did the other sideComment
