E39 m54 owners help
  • bmwm42
    • 6300
    E39 m54 owners help
    Ok so my e39 wont start the problem ive traced the problem to no fuel. The pump is not engaging. if I spray starting fluid in the cylinders it will start. I tried jumping the relay pin 30 and 87 and still the pump doesnt engage. I checked the pins they are getting 12v. Is the problem the fuel pump? Please help me figure this out.
    Originally posted by bmwm42
    PNW vulture pm me for parts
    Strategic nw e30 command
  • 10Toes
    Me Father Was A Tree
    • Jan 2008
    • 61222
    If the pump is getting 12v and not turning on then its a bad fuel pump.
    you should be able to use an after market pump like you can in e30's, I know you can in e36 and e46's.
    • bmwm42
      • 6300
      Misread the pump is getting no power there is however 12v where the relay is but the relay isny opening I tried jumping and still the pump won't engage
      • brutus87
        • 6280
        Cps!
        Cps!
        Check the guess what.....
        Cps!
        • brutus87
          • 6280
          Crank position sensor.
          check to see if its unplugged.
          • bmwm42
            • 6300
            Guey its plugged in the motherfucker just died while driving I checked both cam sensors there fine I have a strong spark just no fuel no pressure at the rail.
            • AbeSonic
              Price check on Vagiclean, aisle five. I repeat: price check on Vagiclean, aisle five. That's Vagiclean. We've got a customer down here with a full-on fallopian fungus. I'm baking a loaf of bread and I think it's sourdough.
              • 3635
              Bad fuel pump?
              out dated sig is out dated
              • dj01540i6sp
                • Jan 2009
                • 349
                Hot wire the pump if it turns on! Then get an ohm meter and a Wiring schematic. GL
                • Curt Hayes
                  • 476
                  Bad relay
                  S52-Powered 1987
                  • nrubenstein
                    • 3148
                    Check your fuses. In particular, there is a little bank of about five fuses in the compartment behind the RF strut tower. If one of those is out, it can cause a no start scenario and you'll never, ever figure it out without someone to point you.
                    The e39 has 3 different locations for fuses, which is so utterly beyond ridiculous, it's just not funny.
                    2002 BMW M3 Alpinweiß/Black
                    1999 323i GTS2 Alpinweiß
                    1995 M3 Dakargelb/Black
                    - S50B32/S6S420G/3.91
                    1990 325is Brilliantrot/Tan
                    1989 M3 Alpinweiß/Black
                    • bmwm42
                      • 6300
                      Thanks for the info ill look at those fuses
                      • cbouchez
                        • May 2007
                        • 2789
                        It sounds like the cps
                        Follow my IG @bouchezphotography
                        • bmwm42
                          • 6300
                          Crank or cam
                          • mikeedler
                            • 6707
                            wiring harness, pump, or relay. I would go more toward the route that the pump is what is wrong, but if it truly is not receiving 12v at the pump, then it must be the wiring if you're jumping the relay correctly. I just replaced a pump on a e39 M5 a few weeks ago, not a hard job.
                            • bmwm42
                              • 6300
                              Yea pump is a piece of cake to replace I already have everything ready just waiting for the pump
