89' 325i m20 wont start!!
  • spiDmang
    • 3941
    hey guys,
    today i went out to the car to go run some errands when the car wouldnt start.
    I did a stomp test, and i didnt get any fault codes. the car will crank for days, but its not turning over. i can smell fuel from the exhaust tips, and im not hearing the fuel pump "click on", as if its not operating??
    any ideas guys? ive been searching for hours, and cant diagnose a thing...
    91' 318iS - S54/6MT Swapped
    08' E90 M3 6MT - Daily
    Originally posted by IronJoe
    Originally posted by 2mAn
  • e30austin
    • 15382
    Check crank position sensor.
    • AbeSonic
      Price check on Vagiclean, aisle five. I repeat: price check on Vagiclean, aisle five. That's Vagiclean. We've got a customer down here with a full-on fallopian fungus. I'm baking a loaf of bread and I think it's sourdough.
      • 3635
      Where are you not hearing your fuel pump? You need spark, timing and fuel to get the car to start. Check for spark the coil.
      out dated sig is out dated
      • Eta power
        • 342
        Fuel pump relay?
        Originally posted by 5Toes
        bux bux bux. Im all about the bux Mr. Autism
        • Edev
          • 3731
          Don't forget that you also need pancakes as well.
          M Coupe
          • spiDmang
            • 3941
            noob question, but where is the crank position sensor located on an m20?
            ill also check fuel pump relay.
            • bmwm42
              • 6300
              At the crank
              Originally posted by bmwm42
              PNW vulture pm me for parts
              Strategic nw e30 command
              • timofeylbelarus
                • Dec 2010
                • 326
                same thing happened to my eta, except when i was taking it apart i shorted the red wire on the fuel pump and now it doesnt start
                1985 325e - wrecked :( (being fixed and full paint job)
                http://www.r3vlimited.com/board/showthread.php?t=197989
                the horrible day
                http://www.r3vlimited.com/board/showthread.php?t=210850
                1991 318i - in process of being made a DD
                http://www.r3vlimited.com/board/showthread.php?t=219793
                • spiDmang
                  • 3941
                  same exact symptoms...
                  • spiDmang
                    • 3941
                    is there a DIY on replacing the CPS?
                    • AbeSonic
                      • 3635
                      Maybe? Idk use the search feature this wonderful website has lol. You might be able to reach it/see it but there might be stuf in the way. On the crank on the furthest pulle away from you, (the one touching the block), on the upper right portion you will find the cps. Did you check for spark at the coil yet?
                      • AbeSonic
                        • 3635
                        Yes and pancakes as well.
                        • goinstrong
                          • Jul 2008
                          • 215
                          The crankcase position sensor is on the passenger side near the front of the block between the oil filter housing and the distributor, but closer to the ground. It is held in by one bolt or nut, and the wire feeds back to the other side of the engine by the water pump.
                          If you have spark, I am not sure this is your issue. I think (someone correct me if I am wrong!) that you won't get spark if this part isn't working properly...
                          Tim
                          • spiDmang
                            • 3941
                            ok guys, i found the crank position sensor (also called the "pulse sensor" or "reference sensor" in the bentley)
                            I'm going to test this bad boy, but the damn 5mm hex nut seems stripped beyond belief! any good way to remove this bitch?
                            • spiDmang
                              • 3941
                              i checked the resistance of the coil, and the ohm reading is .7 - .8...bentley says resistance should be roughly .50
