ahhhh m50 engine swap
  • e304m3
    • 263
    Doing my swap right now, and trying to place the engine onto my e28 535i mounts. Can't get the engine to match up right. I'm in lynnwood at performance motors right now. If anyone is local and has done the swap and could come lend some advice or reply back to this it would be appreciated. I've read the the comprehensive dohc thread and can't seem to find the answer.
    Thanks
    Mick
    performance motors located on the corner of 212th and 67th a block east of aurora
    86' silver arctic metallic es
  • e304m3
    • 263
    or call or text me at 206 992 1168 thanks
    • Jafxod
      • May 2011
      • 1301
      Get the trans pushed all the way up into the tunnel and get the motor all the way back into the bay. Keep the bolts on the mounts holding on by like 2 threads so you can angle them to fall into the subframe (or the other way around)
      • e304m3
        • 263
        the trans if off, were just dropping the engine and going to add the trans from the bottom later (benefits of having a lift). If I line up the passenger side mount, the drivers side is off by an inch. We were keeping the mounts loose so we could have some play, but they still aren't matching up well. I'm baffled ha
        • yanal
          • Jun 2011
          • 248
          I just did the same thing last night and it took me almost an hour to drop the engine in ! I had the transmission mated to the engine tho.
          I had the engine on a hoist and the car on the lift then I jacked up the rear of the transmission up with a floor jack, then kept shaking in it around until I got the passenger side in, then the other side didn't take as long,do not screw the mounts until your engine is seated. I'd also install the transmission while the engine is out, since the two screws on the top are a nightmare !
          Sticky:True e36 one touch windows DIY
          1990 M3
          1992 Mtech (S50 + 5 Lug)
          • e304m3
            • 263
            Thanks guys, got some different mounts and got it in snug. got the tranny all bolted up and coupler comes tomorrow from revshift for the driveline and then the wiring begins!
            • yanal
              • Jun 2011
              • 248
              Congrats and good luck !
              1990 M3
              • Jafxod
                • May 2011
                • 1301
                Good job. I always underestimate the pain in the ass of getting the 24v motors on their mounts.
                • e304m3
                  • 263
                  yea, wayyy more of a bitch than I thought it was going to be. Took way too much of my day.
                  • LuckyHenriksen
                    • Jun 2010
                    • 4244
                    This. One of those things that adds an unexpected hour or more to your build time
                    Bahama Beige E23 Project
                    Bluebird Bus Conversion
                    New Oregon Trail
                    • yanal
                      • Jun 2011
                      • 248
                      Hey did you have to flip the e28 mounts for the transmission to sit right ? After I finished installing everything the transmission didn't look right and couple of members here told me I should flip the mounts.
                      1990 M3
                      • e304m3
                        • 263
                        I tried that and they still didn't work right. So we re ordered some mounts from a 528, they look like the ones of this page, http://www.r3vlimited.com/board/showthread.php?t=123482 and the engine sat right in. With these mounts we were able to use the stock mounts (that came off the e30) for the zf tranny from the m50. Unfortunately, we had to cut the shift linkage, shorten slightly and re attach at a 5-7 degree angle, so that when shifting, the shifter wouldn't come in contact with the center console.
                        • yanal
                          • Jun 2011
                          • 248
                          How come everyone is saying the 535i mounts work fine ? I removed the engine again today and flipped the mounts, it kind of fixed it but I still don't like it, I'm going to buy some of these mounts you mentioned. And thank god my shifter carrier is almost centered and I didn't have to cut or weld
                          1990 M3
