So I bought an E30 today, and the guy said the shifter bushing needs to be replaced and the linkage needs to be tightened. I called Signature BMW and he wants $300~ to replace the entire bushings and reseal the tranny. I'm also going to replace the t-belt, waterpump, and t-stat and got a quote of $450 for that, which is okay. But is that too much, it seems like it is. Parts are about $100, but how can labor be $200..
Shifter linkage/ loose shifter
Tags: None
Well I really don't have the tools or time to do it, thats why I'm trying to do both of these things at the same time.Comment
If you want to drag your car down to PDX I will be happy to rebuild your shifter and replace your T-Belt and water pump :)Comment
No, you do not need to. The only thing you need to do under the car is disconnect the cir clip that holds the selector rod to the shifter. Really simple.
