Weird low beam issue...Help!!!
  • spiDmang
    • 3941
    Hey guys,
    my driver side low beam has been acting up. Whenever I turn on the low beam, the light output is VERY weak (almost like a city light). On top of that, the driver side high beam is also on and is also very weak??
    I have no idea where to start. Also if I try and disconnect the high beam connection and turn on the low beams, the driver side won't work. The high beam has to be plugged in to get any type of light output
    Any ideas??
    P.s. fuses are good, bulbs are new. Would a faulty relay cause ONE low beam to act so finicky?!?
    91' 318iS - S54/6MT Swapped
    08' E90 M3 6MT - Daily
    Originally posted by IronJoe
    Originally posted by 2mAn
  • e30austin
    • 15382
    I would stick another relay in there just for shits n' giggles. Can't hurt.
    • iansane
      • 1343
      Bad ground on the low DS low beam?
      84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
      • spiDmang
        • 3941
        Are you referring to the ground that connects to the bulb? If not, does that ground connected somewhere in the engine bay?
        • PNWDan
          • Feb 2011
          • 1326
          Low beam and high beam relay are different. Has someone done the pin jumper between them to run highs and lows at the same time? If so, I would look there and the relays first. If not, it sounds like you have a short in the loop somewhere.
          1987 Alpinweiß 325is
          Like the PNW E30 Local Crew Facebook page
          • iansane
            • 1343
            Not necessarily at the bulb itself. I've seen many 4light systems that develop a bad connection to ground on one low beam circuit. The electricity travels wherever it can and you get ~12v to both the high and low beam and a really dim bulb on each, or a normal-ish low and a constant on dim high beam. Not staying this is definitely your issue, but it's worth looking into when you mess with the relays.
            • spiDmang
              • 3941
              ~12v to both the high and low beam and a really dim bulb on each, or a normal-ish low and a constant on dim high beam. Not saying this is definitely your issue, but it's worth looking into when you mess with the relays.
              This is the exact situation I have. But I don't get any
              Light output if I don't have the high beam hooked up. Should I look into new relays?
              • iansane
                • 1343
                I'd go after the ground on the low beam first. It sounds to me like the ground is gone and it's using the high beam circuit as a ground. When the high is unplugged there is no where for the electricity to ground out and it doesn't work. You have a DVOM? Check continuity between the ground terminal on the low beam head light connector and the chassis/bad/strut bolt/any solid ground.
                • spiDmang
                  • 3941
                  Ahhhhh...thanks for putting that into nooblish (English for noobs)...
                  So theoretically speaking, if I grounded the low beam elsewhere, the light should work?
                  • spiDmang
                    • 3941
                    This was exactly the issue. Thanks a bunch bud! Now I can drive at night for late night munchies!
                    • iansane
                      • 1343
                      Jackpot!
