Spring Compressor?
  • Wschnitz
    • 8089
    Spring Compressor?
    I want to switch back in my sport springs, anyone have a spring compressor i could borrow?
    willschnitz
  • butters
    • 1205
    Autozone "rents" them for free fyi.
    • cbouchez
      • May 2007
      • 2789
      +1^^
      Follow my IG @bouchezphotography
      • JBird
        • 980
        What sport springs do you have?
        I have the IE Stage 3 springs and they were incredibly easy to install in the rear. No need for a spring compressor or pry-bar.
        And the stock springs shouldn't be too hard to just pry out with a pry-bar or something. Probably a lot safer not to use a spring compress too.
        "The Camry is an appliance, not a car. It attracts folks who have the same regard for driving that they have for washing dishes,
        i.e. it's a necessary but somewhat unpleasant chore and they want something to make the task a little easier and insulate them from the process."
         - my friend, Número Veintiséis
        • 10Toes
          Me Father Was A Tree
          • Jan 2008
          • 61222
          Thats cool, how do you do the fronts?
          • e30austin
            • 15382
            • JBird
              • 980
              Just put new wheels on my car, so I didn't change the fronts. I only took out my IE Stage 3 springs in the rear to replace with stock in order to pull fenders. Then put Stage 3's back in.
              I would imagine the fronts wouldn't be too different from how the rears come out...
              • LuckyHenriksen
                • Jun 2010
                • 4244
                Fronts require significant compressing. Be safe when the spring is under pressure it can cause a lot of damage if it slips
                Bahama Beige E23 Project
                Bluebird Bus Conversion
                New Oregon Trail
                • ethirtydavid
                  • Jan 2008
                  • 2331
                  +1 autozone and schucks will rent them out for the day- bring them back and there is no charge. maybe thats why schucks is out of business........
                  be somewhat even while you are compressing each side down-
                  • butters
                    • 1205
                    lol using a prybar is going to be alot more difficult in the front, extremely unsafe, and probably damage your fenders. the stock springs were a bear even with the use of a compressor.
                    • Wschnitz
                      • 8089
                      I'm putting in cheap bavauo 1.5in lowering sport springs. Thanks for the AutoZone tip. I only need to do fronts.
                      willschnitz
                      • bmwm42
                        • 6300
                        There is nothing difficult about the fronts use a good spring compressor do it evenly and your fine
                        Originally posted by bmwm42
                        PNW vulture pm me for parts
                        Strategic nw e30 command
                        • 5Toes
                          • 9836
                          ^ yup. Put the strut housing in a vise (wrapped in a towel) if you're doing it off car
                          • e30jake
                            • Feb 2012
                            • 855
                            What it feels like owning an e30:
                            88 325 S50 swap in progress
                            90 325ix
                            • Wschnitz
                              • 8089
                              Sounds good. Also is there a way to tell the difference been normal Billy sport shocks and HD's?
                              willschnitz
