Found this on craigslist, if I had an extra $3,000 laying I'd definitely grab it.
Engine is an M106 European turbocharged engine (BMW OEM Turbo engine). 3.5L in line 6 cylinder
It is a great running engine, always synthetic oil(mobil 1), always on time, not a daily driver) (ran at 10psi) (Air conditioning is still usable with this set up)
This set up is a plug and play for BMW 535i years 89-93 or BMW 735i 88-92 and could also be used with any other BMW which uses the M30 3.5L engine but will require a programmed ECU.
This is a reliable engine that can get your old Bimmer back in shape and take the Pepsi challenge with all the new stuff out there.
The extras include
-Easily able to run up to 20psi by just changing the waste gate valve spring. (Lots of potential for more power than what I was getting)
-Rising rate fuel pressure regulator
-Big injectors
-Bored Throttle body
-Metallic Layer Head gasket. (not a ring gasket, will not leave indentations on cylinder head)
-ECU with Turbo programmed chip
-Manual boost controller
-Boost gauge
-Cooler temperature aux fan temp switch (from bav auto)
-Intercooler
-Motor mount necessary for install on E34 535i
-Air flow sensor set up for E34 535i
-Intercooler brackets necessary to mount in place of washer fluid reservoir.(Hood vent is necessary for this set up)
-Air tubing for install on E34 535i
-Free AC compressor along with purchase.
This set up will run comfortably between 10 and 12 psi, but certain mods can be made to run up to 25psi.
Price is $3500 or best offer.
Limited Slip Differential available. Price is $320 or free with engine purchase.
Call or come in and check it out.
Tires & Parts Auto Wrecking (Seattle) (206)242-4856
10432 15th SW, Seattle WA 98146
The extras include
-Big injectors
-Boost gauge
-Intercooler
