All parts located in NE Portland and prices are OBO. I need to park my car in my garage, not a bunch of stuff.
Text or a call is the best way to reach me. I work late so you can call until midnight.
Steven
503.913.7539
Medium diff cover with decent but not great rubber mount $10
Working slave cylinder from 87 325is $15
173 ECU, it has a chip but I don't know which one. Comes with stock chip too $30
Working AFM from 87 325is $40
e36 mirror $5?
e36 vacuum reservoir $5?
OBD1 ISV $10
OBD2 fuel rail $5
e36 stainless brake hoses $30
OBD1 throttle body, clean as a whistle $25
Oil cooler from 87 325is $15
Blk leather sedan seat bottom. Its in really good shape but a little dirty from living in the garage. The white schmutz wipes off with a little spit on my thumb. No worries. $40
Blk leather top half from a coupe. Has a couple of split seams at the top. Otherwise nice and supple. $20
3.5bar FPR fits any e36 24v motor. Works for OBD1 or 2. One is brand new and the other is working perfectly but used. $45 and $15
Husco arm rest with all the hardware. In great shape, just a little wear on the leading edge. $40 SOLD
Half shafts or stub axles that fit e30 axles. I think people need these when using e28 diffs. $15
I also have the diff case and input shaft if you want it. $10
PS pump from a 24v motor. $10
Early m20 radiator. Its less than a year old. no temp switch or resistor.
$75 with the fan
$70 without it
Used clutch and pressure plate from a G260. More than half its life left.
$40
M50 manifold and 19lb? green top injectors (all pintle caps and o-rings intact.)
$50 for the manifold
$50 for the injectors
e36 dash. It comes with the glove box and key as well as the shifter surround. $15 SOLD
Text or call
Steven
503.913.7539
Steven
503.913.7539
e36 mirror $5?
OBD1 ISV $10
OBD2 fuel rail $5
$75 with the fan
$70 without it
$40
Text or call
Steven
503.913.7539
