Willing to pay for some help in Tacoma!!
  • mother_russia
    • Apr 2012
    • 421
    So I'm willing to pay someone to come to my house and help me get my car running. I need someone that knows what they're doing and won't mess anything up.
    I did a motor and manual tranny swap into my 1990 e30 sedan and now have a problem starting it up. Its just another m20, but with low miles. Motor turns and gets fuel, but doesn't get a spark. I've just recently installed a brand new engine harness and have like 2-3 connections left to connect, but not sure where the hell they'd go.
    Please. Someone hit me up and help me out! I'm willing to pay!!
  • EN318isPDX
    • Oct 2007
    • 4373
    Post pictures of said connectors and what motor did you swap
    • mother_russia
      • Apr 2012
      • 421
      It's just another m20. And here are the connectors http://www.r3vlimited.com/board/showthread.php?t=272114
      • DÌEGØ
        • 690
        Bored as fucki would totally be down if i was closer. Check if ur getting pwr/grnd at the coil
        Driving:1990 325iS, 2007 335i :devil:
        past BMWs: 1987 325iS turbo, 1989 325i, 1995 525i, 2000 328CI, 2001 540i, 2008 135i
        • Mlarsen
          • 4082
          If my car doesn't take me all night I'll swing and see if its something obvious.
          edit: Where in Tacoma are you? I'm really not trying to drive out to NE.
          • mother_russia
            • Apr 2012
            • 421
            Diego, come down and I'll pay you for gas!! :D
            And to be exact, I live in University Place. It's right next to Tacoma.
            • mother_russia
              • Apr 2012
              • 421
              • mother_russia
                • Apr 2012
                • 421
                Anyone else wanna come down?
                • TwoJ's
                  • Oct 2005
                  • 4908
                  Like people have said in that thread... it looks like the CPS and ICV plugs. First of all... what is your crank position sensor plugged in to? If you're not getting spark, that is an extremely likely cause. Also, what is your idle control valve plugged in to? Can you really not find anything that isn't plugged in? Are you sure you've got all sensors etc. installed on the engine?
                  If you don't know what the CPS is, it is the sensor on the passenger side of the car that would be near your AC compressor if you have one. It mounts very close to the toothed wheel that is on the crank pulley. The sensor mounts there, and the wire runs in front of the timing cover to the other side of the engine bay. It goes to a little bracket. Just search on here and you'll come across a ton of threads about the CPS with photos.
                  I am just going off of memory here, but I believe the bracket is near the front of the intake manifold, or it might be under it a bit. Look around the area of the thermostat housing/intake manifold etc. Again, use the search and find some info/photos.
                  If I wasn't so extremely busy I would come over and give you a hand.
                  • karlorado
                    • Jan 2011
                    • 264
                    Is your car the smashed one on Alemeda?
                    I live just on the other side of Bridgeport across from the library, I can help any time.
                    • mother_russia
                      • Apr 2012
                      • 421
                      YES!!!!! That's me! Haha oh God. This is embarrassing lol. I'll hit you up with a pm!
                      • kylelauffer
                        • Dec 2009
                        • 624
                        i will help over the phone if you need it...
                        • mother_russia
                          • Apr 2012
                          • 421
                          Well, here's an update.
