Mystery stalling problem. Help needed(FIXED)
  • slowe34
    • Sep 2011
    • 206
    *Update*: it finally died on me. But not like how it was described to me. Last Monday, after sitting for 8 hours at work in the heat, I went to start it and it had a hard start. Took 3-4 long cranks, then started but running rough. Let it warm up and smooth out, no check engine lights, so I started my in-town drive home. After 15 minutes or so, accelerating from a stop light, it died. And it was as if someone turned the key off. No stumble, just off. Cranked it for a few tries and it came back. Made it home. Two days later, I drove it from Seattle to Tacoma in the midday heat. When I hit traffic it died several times, same as before. Off idle, slow acceleration and then turns off around 2k rpm. So weird.
    So its either losing a signal or getting one to tell it to turn off. I drove back from Tacoma today with no problem. Only things that changed were 8.5 gallons of gas added and no stop and go traffic(but I still hit lights in Seattle before home). Any ideas? I put that it was hot because it was the first few days of real heat this summer, could be unrelated.
    tl;dr: Car dies off idle, accelerating slowly, around 2k rpm. Like the key was turned off.
    So I bought a 87 325e that has an on going problem. It stalls about once a month and then wont start until it cools down. It's not over heating. The ecu has been replaced, wiring harness, crank sensor, relays and the list goes on. A shop has looked into it and Robert1700 has spent a fair amount of time trouble shooting with no luck.
    I bought the car for a summer internship, where I need reliable transportation. But the more history I get the less I feel like this car will do it. Does anyone have any insight? I do have experience with trouble shooting and thought I could track down its flaw, but I am worried I might not. I guess I am just looking for words of wisdom/encouragement here...
  • e30austin
    • 15382
    Fuel pump.
    • slowe34
      • Sep 2011
      • 206
      Originally posted by Austin!
      Fuel pump.
      I thought that too. And there was a broken up unit in the trunk, so Im not sure if it was swapped out or not. How do I find a "once a month" fuel pump problem though?
      Nice 4 door on e38 style 5's :)
      • e30austin
        • 15382
        It's hard to say. I worked on a Taurus that had a very similar issue and it was very intermittent. I just changed the pump and it went away.
        Thanks! Yours looks nice too.
        • PNWDan
          • Feb 2011
          • 1326
          "T" in a fuel pressure gage to the rail. When it stalls, jump out n pop the hood to see if you lost pressure.
          1987 Alpinweiß 325is
          Like the PNW E30 Local Crew Facebook page
          • EN318isPDX
            • Oct 2007
            • 4373
            Just because no one said it. Fuel filter?
            • slowe34
              • Sep 2011
              • 206
              So, it looks like most people are leaning towards a fuel delivery issue.
              I have a fuel filter waiting to be swapped in(only have time on weekends to work on this).
              What about the FPR? Could that possibly be affected by heat and then crap out until it cools off again? Leaky injectors? I guess I'd rather start with the cheaper parts first.
              I should also add that the stall only happens when you come to a stop after a fair amount of around town driving. Never occurred on the freeway. Or so I was told.
              • kid325e
                • Sep 2007
                • 6422
                Here are my thoughts.
                Broken up FP in trunk means it was probably replaced.
                87 Eta leads me to believe the PO probably was a cheap ass and replaced it with a used unit. Do what PNWDan said, should be a surefire way to single out the pump?
                clutchCTRL!
                Move with a purpose.
                - 1991 325iX 4dr/5spd
                - 2000 323i AT
                2016 Mazda CX3 Sport AWD
                • slowe34
                  • Sep 2011
                  • 206
                  PO said it was a "spare". He never turned a bolt on the car, so he wasnt very much help. Also, it was just the pre-pump, as 87 still had the in line HP pump.
                  But when I do the filter I will do the pressure gauge too. Now I just need to find one for cheap. I was thinking of just using the HF fuel pressure tester: http://www.harborfreight.com/fuel-in...ter-92699.html
                  • slowe34
                    • Sep 2011
                    • 206
                    *see first post for update
                    • Pdxseth
                      • May 2012
                      • 3124
                      My car did that when the top of the coil was corroded
                      • BigBillions
                        • 123
                        car dies at random
                        I think the grounds, or something to do with electrical connections if it was fuel I would think it would do some sorta sputter, but just losing everything like turn off a light switch. Makes me thing electrical.
                        • MT325is
                          • May 2012
                          • 1103
                          My car did that when my tps went out. It just died. So I got a new tps.. And still had stalling issues. Put new afm(mine was bad) on still had stalling issues... Only at cold engine tho.
                          Put new intake boot on. Problem solved. And no more cel either. Good luck. Your best bet would be find a friend that has a perfectly running car.. And swap parts..
                          1989 BMW 325is (SOLD)
                          1992 BMW 325IC (SOLD)
                          1991 BMW 318IS (STOLEN!)
                          2017 BMW M2 (WEEKEND WARRIOR)
                          1989 BMW 325IC (PROJECT(
                          2002 FORD ESCAPE (DAILY)
                          • Pdxseth
                            • May 2012
                            • 3124
                            Did you figure it out?
                            • BigBillions
                              • 123
                              solved or not
                              update bro plzs is it fixed? and if so what was the issue?
