hi there, sad story here....
my bmw (1986 325e) has been sitting for a while as a half finished project.
and im looking for someone within the e30 community to commission to finish it up.
this is how it went, car drove great... eventually the clutch started to go and it had an oil leak from the front and rear main seal, and head gasket. when it got bad enough I parked it, purchased a 325i longblock and went to work.
I was in the process of rebuilding the 325i longblock I purchased out of seattle when I got to the crank bearings.
they were TOASTED.
So I accepted my loss and did some refreshing on the 2.7 block. put the 2.5 head on that. put it all together, timed it up on the engine stand. it turned fine.
then put the flywheel on, clutch, transmission and dropped it in the car.
I put it all together and went to start it and realized the motor wasn't rotating for ANYTHING. at all.
pulled the starter, pulled the crank pulley, disconnected the drive shaft and put the transmission in neutral, still nothing.
I would like someone to get this motor spinning, bonus if you feel comfortable getting it running for me.
i'm fairly handy mechanically but i am OVERWHELMED with work, and plus my garage is a mess I wouldn't even know where to start looking for tools.
if this is something that interests you, let me know on this thread. or feel free to txt me with questions.
503 290 6390
maybe come by and we can discuss how much I need to pay you to get this car back on the road.
and YES I understand this isn't something that can be solved with a case of beer and 50$, your time and knowledge is valuable.
they were TOASTED.
503 290 6390
