Must be from a 93-95 525i I believe. Willing to come to you or meet you in between if need be. Reply in Pm or in thread if you have what i need and we can go from there.
WTB E34 525i 5 speed driveshaft
I have one from 92 525i (m50nv with G250)
LMK if it will work for you or not.
Thanks"i love vee tek, its a wonderful sound when you driving right by it"
If you bought anything from me, please leave a feedback here: http://www.r3vlimited.com/board/show...ghlight=drulle -
I dont think that will work, they made a change in the size of the part that connects to the driveshaft to the transmission at the same time of adding vanos to the M50, so if it was vanos it most likely would work but it unfortunately isn't. Thanks though!
On another note, we still need a driveshaft to finish this 5 speed conversion!Comment
Nv cars have zf sg310 with 96mm guibo.
Vanos cars had getrag g250 with 84mm guibo
Diff sides are also matching 96mm/84mm cv
My 92 525-5mt had a 96mm cv flange on the original 3,23 diff I needed to retain and install on the new unit when I replaced it with a built 3,15 diff. Trans side must obviously match.
Sent from my SAMSUNG-SGH-I337 using TapatalkOBD1 M54/M52TU swap as a M50b25
That explains it, we need the 84mm. We have 2 different driveshafts right now but they're both bigger then the flange.Nv cars have zf sg310 with 96mm guibo.
Sent from my SAMSUNG-SGH-I337 using TapatalkComment
Yes bmw made the e34 horrifically complex. Imagine the added puzle in europe with xi models and diesels!
The m20 g260 cars and m30b35 g260 and m60b30 cars have similar drive shafts 96mm both ends.
The zf310 cars (non vanos like my 92) 96mm both ends
The g250 (vanos m50) have 84mm both ends.
Shift linkages and trans mounts seem to all be different; easiest to just order new bmw oem from blunt.
Hmmm... mine is NV but came with G250 not ZF tranny."i love vee tek, its a wonderful sound when you driving right by it"
If you bought anything from me, please leave a feedback here: http://www.r3vlimited.com/board/show...ghlight=drulleComment
