Has anyone wired up euro smileys?
  • ser1992
    • Feb 2013
    • 482
    I have sealed beams and a set of Bosch smileys ready to go in. has anyone done this before... Im good with mechanical stuff but will burn my car to the ground along with my apartment complex if I get into wiring stuff :(
    I'll pay someone to bust out a clean install
    PM me if interested and near Seattle
  • Wardie
    • Oct 2012
    • 824
    Ive done mine, its been awhile though.
    Schwarz 1985 325e
    • NoSnowJustIce
      • Jul 2012
      • 169
      Mine have been working for a while. But I'm unfortunately 5,500 miles away for a while.... Write-ups weren't too hard to follow in the past.
      • e30austin
        • 15382
        There is a write up in the general technical section if you're running HIDs. If not, you can figure it out with a simple test light, but it's fairly simple, regardless. Brown is always ground. You'll need to do some relay modification if you want to have functioning high beams, but that's covered in the DIY.
        • iansane
          • 1342
          Even if you don't do the relay mod you have functioning high beams, the lows just don't stay on (which I admit, defeats a bit of the purpose...)
          Where in Seattle are you located? I didn't go to smileys but I went to regular elips. I could show you what I did on my car.
          84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
          • Wschnitz
            • 8089
            If you use the sidemarkers for the city lights its ezpz
            willschnitz
            • eurotrash
              • May 2007
              • 768
              Low beams use the 2 outer pins. White wire is the power wire and plugs into the non brown wire. Highs are the same way.
              You also have to jump the high and low relays in order to get them both to turn on at the same time. Cant remember which pins you'll have to look that up.
              • ser1992
                • Feb 2013
                • 482
                Thanks for all the insights guys. Im picking up my pigtails tomorrow and will start on this soon. I may reach out to some of you.. if not watch for a car fire on King5 news =P
                • accident
                  • 7303
                  Ugh, stop jumping the fucking relays!
                  The two not brown wires go to the one not brown wire in the pig tail. The brown wire goes to the brown wire. Both lights stay on with high beams active, no ghetto hack relay jumping required.
                  Moral of this story?
                  • D-rock
                    • 714
                    +1 just did mine last weekend.
                    • ser1992
                      • Feb 2013
                      • 482
                      thanks for the note, this simplifies it a lot!
                      • ser1992
                        • Feb 2013
                        • 482
                        So I did the 2 -> 1 non browns and connected the browns on both high and low beams. Now when I turn my headlights on, both high and low beams turn on. I can't turn the high beams off. :/ Ideas?
                        • e30austin
                          • 15382
                          Unplug high beams, done. Lol.
                          No, you'll just need to follow the DIY. Check which wire is hot all the time and which one gets power only when high beams are switched on.
                          • Poorboyz
                            • May 2012
                            • 2117
                            I used this when I did mine.
                            http://bmw.e30tuner.com/articles_eurolight.php
                            Rebuilding since 07/06/2016
                            Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
                            Poorboyz Feedback Thread
                            • accident
                              • 7303
                              That's... odd.
