WTB: small case 4.10 lsd
    Looking for a small case 4.10 lsd, preferably one in good shape without leaks, whines, or blown clutches. Would prefer someone in the Seattle area. I have a 4.10 open for trade if that means anything.
    I might be able to help out, I'll get some pictures and get in touch this afternoon when I get home. I have a small case with a good LSD but the pinion gear is broken as well as the LH bearing support. You could swap gears and support to have a good Small case LSD 4.10.
    2006 Subaru WRX
    1987 E30 Royalblau Metallic S52 OBDii
    1982 VW Westfalia 1.5d-gone
      This might work.
      So this is the Diff in question. with axle stubs and all
      This is a broken pinion that can be removed. Or you can use your existing case and pinion
      And this is the broken bearing support which you could replace with your existing one.
      I bought this on craigslist a few weeks ago with no idea that it was busted, pulled it apart and this is what i found.
      I know its not ideal, but is is an option. all or any bits let me know and we can work something out.
      2006 Subaru WRX
