I have an after market radio. I turn it off and the antenna doesn't go down nor will it go down when I turn the car off. I never use it because I never listen to the radio. Don't thin it looks very good when it's up. Any ways to get it down?
Antenna won't go down
Tags: None
Check that everything inside the motor is good. Assuming your motor is good, you could have a stuck mast as well. Otherwise, you can loosen the nut holding the antenna tight to the motor, and just pull the mast out and plug up the hole.1988 BMW 325iX - Lachssilber/Cardinal - Gone
2001 BMW M5 - Anthracite/Black Heritage
1999 Toyota 4Runner - White/Oak
